Pacesetter off road y pipe restriction
Old 04-09-2011, 10:35 AM
35th camaro's Avatar
Default Pacesetter off road y pipe restriction
Last year when i installed my headers and off road y pipe from pacesetter's every thing went togheter good and liked the quality and fit, but had noticed when looking in the merge pipe that there was a restriction were the 2 pipes join togheter, i was in a hurry the get car finished that weekend and left it as is, but it had been bugging me since, today i cut my merge pipe and cleaned at least a good 1/2 " of meterial all around inside the merge pipe and then welded it back togheter. car is not on road yet so i won't see a difference now and did many other changes. fast 102 intake etc... wish i had taken my camera to take photos, forgot.
Old 04-09-2011, 02:53 PM
dug
dug's Avatar
you should go all out and install the flowmaster merge
Old 04-09-2011, 04:02 PM
What hp advantage would it give.
Old 04-09-2011, 04:38 PM
Bird's Avatar
I noticed the same thing in my Pacesetter Y - took my extended carbide cutter from the porting set and cut it out - definite difference as the blockage from the overlap was on the long radius of the driver's side pipe and was causing a lot of reversion. Engine feels much smoother and not nearly as much rasp.
Bird
Old 04-09-2011, 04:45 PM
Captain Double Post
BOBS99SS's Avatar
Flowmaster merge,best move!
Old 04-09-2011, 05:33 PM
24/48's Avatar
Since you can weld grab a FM merge.
Old 04-09-2011, 06:04 PM
dug
dug's Avatar
10-15rwhp and a lot more midrange torque
Old 04-09-2011, 08:09 PM
other than Bird, has anyone done the mode to the pipe and seen difference before and after?
Old 04-09-2011, 09:52 PM
Pontiacerator
RevGTO's Avatar
My "XS" (now LPP) Y was a knock-off of the Pacesetter Y in stainless. I did the same and ground down the extra material in the merge. Eventually I had the merge hacked off and had the pipes connected to an 3"/3.5" FM merge and reinstalled it. Not a work of art but flow has to be far superior.
Old 04-10-2011, 12:34 AM
jsteele90's Avatar
definitely get the FM merge. its next on my to do list
Old 04-10-2011, 01:08 PM
thegodfather899's Avatar
sounds like this will be my next step as well
Old 04-10-2011, 01:32 PM
Steve Gunn's Avatar
I'll let you know. I'm going from a pacestter Y to a 3" to 4" FM merge. My butt-o-meter will be the test.
You remember how your Y looked even after you hogged it out?
Here's the FM.
Quick Reply: Pacesetter off road y pipe restriction
