bad balancer (vibration @2500)
I have a 2004 m6 gto and I've noticed it has a slight vibration from 2200 to 2800. Anything after 3000 its smooth as can be. Its not in the drive line. It does it in neutral too. I think I'm going to start with the balancer first. Any ideas?
installing an upgraded dampner will not help vibrations other than vibrations rooting from the dampner itself. the dampner does nothing but keep engine vibrations out of the accessory drive, and turn it.
if there is a vibration from the engine, this needs to be addressed seperatly, changing the dampner will not cure an internal engine vibration.
