Modified Intake Idea! Input welcome
1 Post
So Im currently waiting for a Wieand Lingenfelter intake to arrive at my house and I had and idea. Since the intake is aluminum has anyone tried cutting the 80 mm flange off and TIG welding on a 90mm opening? From the bit of research I have done it seems to me the intake flows about as well as the LS6 and they have had good luck putting the 90mm opening on them, but that is way way overpriced in my opinion.
1 Post
To be honest there is no way i can get a PP intake for the price im getting this for. For $30 i can get the flange shipped to me and my welder can tig it on for another few bucks.
Kleeborp the Moderator™
The throttle body opening size has very little to do with how well an intake manifold performs. That is dictated by the runner size and shape.
I think you will end up wasting your time, especially if you think it'll net you the performance of a FAST because you were able to mimic the throttle body size of one of their previous designs.
1 Post
So is anyone getting the concept im trying to get across. I am not by any means thinking im going to make something better than a fast intake. Im just thinking that with the intake I have coming that i could try and make something similar to this setup. Still stupidly over priced.
http://www.lingenfelter.com/mm5/merc...egory_Code=C35
I think you should dyno the intake on your car first then Modify it and dyno agin. I think it's a cool idea. And if the welder is any good then welding on the intake will be no problem. I have tig welded investment cast patterns for years now in a foundry. We do mainly aluminum castings. And for your information most intakes are are made of 319 aluminum at least which welds very easily. Should be no problem
I agree it should weld easy enough & give you a small increase in higher rpm range.Others will always disagree with spending money on a part & then modifying it for good reasons, but if you wanted that intake anyways, then the mod is no big deal in hot rodders terms.
I,m currently thinking about building my own cross ram intake on a budget, Which I posted a thread on in this section. It,s an ambitious nuts project , but that's what it takes to be different.
I think it's an awesome idea. These days most folks don't think like that anymore. If it isn't made at "the factory" it won't work, blah, blah..... These ideas take the hot rodder's mentality, that you don't always have to get things accomplished using your check book or credit card. I hope it works out, keep us posted.
1 Post
I think i will give it a shot. Im trying to get ahold of wieand to find exactly what the intake is made out of to make sure we can weld the parts together.
1 Post
Well after contacting Weiand the intake is cast from 319 aluminum, I already was able to get some 92mm I.D. 1/4" wall 6063-T6 aluminum pipe. All that I need now is for the flange to and intake to arrive in the mail.
It is probably a sand cast intake which is the cheapest old school casting process and it will weld just fine. Just make sure to keep it all square and and take your time making small tack welds to start with. Measure the intake before removing the flange and neck so you can place your new flange back in the same spot.
By the way, most cylinder heads are sand cast. Most intakes are sand cast. Look at Edlebrock. There foundry is in Arkansas i believe and they cast most if not all there products there with "green sand".
I'm sure what 01ssreda4 was meaning, by cheap castings but if it's 319 as I mentioned and you stated then there will be no issue of welding. The heat or temp of the metal is what makes the mold: the gating, down sprue or vents if needed: W work properly.
I can't wait to see pictures of the finished product. It's cool to see others making or moding parts like this
1 Post
squirlNUTZ - Thanks for the info, I did understand what you were meaning in the PM you sent me.
The snout on the intake wont be big enough, it was something I talked with weiand about yesturday on the phone. As for the 3/8" barbed fitting im running a custom catch can setup, so I can either drill & tap the snout for a fitting or run the hose up to the throttle body vent that I normally plug. Im trying to find a throttle cable bracket, but I can just fab that up in my garage and mount it on the bolts that will hold the throttle body on.
