DD in big trouble need some desperate help
Old 04-16-2012, 03:05 PM
needtransam's Avatar
Default DD in big trouble need some desperate help
UPDATE 2: Clean the injectors by taking out the fuel rail and everything is good just that I have a leak or the fuel pressure regulator is bad
Willing to sell racetronix pump with whole bucket assembly and practically brand new sending unit for $170 let me know if anyone interested
UPDATE: Didn't state this but when I installed the pump I didn't changed the sock in the bucket only the one for the pump that comes with the racetronix kit, and I also have a brand new fuel filter and tank is full of gas
Ok here is the story
I ran out of gas on my 01 z28 Friday afternoon, put some gas in it it started right up and it drove find for an hour or so, after that my car seemed to loose power and SES light started blinking which means a misfire,
Went to autozone and got a code for a misfire on cylinder 7, took the car to my auto class at my local community college and I changed the fuel pump for a racetronix pump and hooked everything up, i primed the pump several times and it started right up and seemed to work fine.
Im still having the issues with the misfire and seems in the morning my car has to be cranked at least twice to work, so is this normal for a racetronix pump, seems I have to prime it at least twice??
Here is a video really rough idle
http://www.youtube.com/watch?v=zu5_-11_eaQ
Old 04-16-2012, 03:11 PM
heymoej's Avatar
did you undo the battery at install?
just a thought......
even if you did,try undoing the battery again & see what it does? it might need to clear codes & relearn?
good luck!
Old 04-16-2012, 03:16 PM
I didnt undo the battery when I installed it good idea to make my fuel trims relearn
Old 04-16-2012, 03:29 PM
Z284U2TRY's Avatar
check the plugs yet?
Old 04-16-2012, 03:32 PM
not yet but im curious to why after running out completely out of gas?
Old 04-16-2012, 04:16 PM
00NBMformula's Avatar
Have u verified fuel pressure? Maybe running out of gas has nothing to do with the misfire if it ran fine for an hour after putting gas into it..maybe coincidental? Id check #7 plug/wire and coil/injector if the only code is cyl 7 misfire
Old 04-16-2012, 04:38 PM
well maybe I speculated, maybe it was like 30m or 20m but for sure the problem did happen right after I ran out completely out of gas since it was running really good as far as I knew before the incident
Old 04-16-2012, 04:46 PM
djfury05's Avatar
check all the plugs, replace the fuel filter, run injector cleaner, clean the maf/air filter, inspect o2's.. I'd check to see if each cylinder is firing individually too with the plugs and arc them to somewhere.
Old 04-16-2012, 05:03 PM
good idea, I did run injector cleaner twice and nothing yet so maybe what im thinking it could be stuck on the fuel filter not letting fuel in? ill check fuel pressure it should give me a good idea?
Old 04-16-2012, 05:29 PM
smg267's Avatar
If it's telling you there is a misfire on a specific cylinder I would personally start there. Call me old school! Kids these days....
Old 04-16-2012, 05:30 PM
smg267's Avatar
Or it could be your windshield fluid sensor.
Old 04-16-2012, 05:41 PM
thats what autozone said though, going to take it to school and get a real scanner and see whats up, i can also look at injector pulse i believe but not sure what parameters are "normal"?
Old 04-16-2012, 06:33 PM
I would pull the spark plug and plug wire and inspect for cracks/burnt wire etc.. or replace if due.. You can swap coils with another cyl and see if it follows that cylinder, or plugs wires and coils lol..but personally I wouldnt swap coils unless ur out of options
Old 04-16-2012, 10:53 PM
i checked spark plug all good as well as wire even swapped it with number two and still misfiring, checked fuel pressure and it goes up to 30 psi and drops instantly to 0, changed fuel filter just in case and same scenario, im lost on what it could be only thing is that in can be my original thought the injectors, easiest way to take them off?
Old 04-17-2012, 12:08 AM
nomasterase's Avatar
your fuel pressure should go up to around 55-60 psi and hold id recheck your pump installation
Old 04-17-2012, 12:18 AM
hcb1700's Avatar
Way too low for fuel pressure. LSX engines need about 60psi.
Old 04-17-2012, 06:23 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Me thinks you pinched or crushed a line when you put the gas tank back up.
Old 04-17-2012, 09:14 AM
VandykeT/A's Avatar
Don't hold me to it but I don't think the injectors would effect the fuel pressure. I would drop the tank/ open my trap door up and check for a bad hose clamp, kinked hose, etc. The #7 miss could be an injector. When the injectors went out on my L98 I could unplug the injector and it made no difference and the plug was as white as snow. It ran fine cold but got worse as it ran.
Old 04-17-2012, 09:34 AM
ok well thats my only hope that the hose is bad or something, for the record I didn't replace the sock that is on the bucket, only the one that came with the racetronix kit which is the one for the pump not sure if it makes a difference
Old 04-17-2012, 10:06 AM
bww3588's Avatar
a blinking SES light means random, multiple misfires, not isolated to one hole. my guess is when autozone pulled the codes, they seen many of them and told you that one code thinking they were all the same.
Quick Reply: DD in big trouble need some desperate help
