fast 90 vs 92
Old 04-29-2012, 08:39 AM
andy-lswon's Avatar
Default fast 90 vs 92
Well after seeing Dyno results of a ported fast 90 vs an ls6, I sold my ls6 intake this week. I searched and searched and couldn't really find a performance advantage between a 90 and a 92. The 2mm bigger opening and something about the way they improved the tb screws and the seal for the tb were the only advantages I could find. Are there any differences in the runner design or is it pretty much the same besides saying 92mm on it in pretty red letters Haha? Is there a difference I'm not aware of? I went ahead and bought a ported 90 bc it was a couple hundred bux cheaper than any 92 I could find
Old 04-29-2012, 12:53 PM
andy-lswon's Avatar
And will the stock map sensor work off an ls1 intake?
Old 04-29-2012, 01:01 PM
BrntWS6's Avatar
The stock map will work but it's not a great fit. Some just put RTV around it but I feared it would come loose eventually. So I bought a 4' x 1" wide piece of flat steel from the hardware store. Bent it in my vice and in about 15 min I had a nice bracket to hold the sensor in place. Then I put a piece of industrial velcro (soft side) on the inside of the bracket just to protect the sensor a little.
Old 04-29-2012, 02:44 PM
andy-lswon's Avatar
What's the GM part # for a new map if I can't find mine? Or does anyone make an aftermarket map sensor that would work better?
Old 04-29-2012, 09:36 PM
andy-lswon's Avatar
Also, what's the best tb to use with the fast 90, nick Williams, fast, ptm, or something else?
Old 04-30-2012, 08:48 AM
dodson55's Avatar
any of them three will do just fine just stay away from cheap crappy made ones
Old 04-30-2012, 10:59 AM
thunderstruck507's Avatar
Do not buy a Fast brand 90mm TB. They are crap. I know...I have one. They stick. Mine is about to come off again so I can do some more grinding and polishing.
The hard part is it only sticks when bolted to the intake, on the bench it works fine so don't assume because you have one in your hand it is "a good one".
Old 04-30-2012, 11:01 AM
andy-lswon's Avatar
I've heard the fast ones have a sticking problem. Texas speed recommends ptm but I can't find a 90mm, they're all 92s or 102s. Will a 92 work on a fast 90?
Old 04-30-2012, 06:01 PM
SweetS10V8's Avatar
FAST 90mm TB, stay away....they stick.
FAST 92mm TB, total redesign, work great use them all the time.
Old 04-30-2012, 07:16 PM
andy-lswon's Avatar
So a 92 mm tb will work on a fast 90?
Old 04-30-2012, 07:19 PM
andy-lswon's Avatar
If a 92mm tb will work, I'm prolly gonna go with either a nick Williams or a ptm. Texas speed speaks highly of the ptm. What do you guys think?
Old 05-01-2012, 08:37 AM
Outside of not buying a POS fast 90mm I would get whatever I found used for the cheapest in good shape. It's a butterfly valve in a chunk of billet aluminum...outside of being poorly machined and sticking there's not much that can go wrong and they all perform the same. I am unaware of any issues with other brands and even the Fast can be fixed it's just annoying to have to take it on and off a dozen times to clearance it without creating idle problems.
If you look around you can save yourself a couple hundred bucks.
Old 05-01-2012, 09:13 AM
andy-lswon's Avatar
Yeah I'm staying away from the fast tb. I'm leaning towards nick williams or ptm. All I can find are 92mms brand new. If I can't find a deal on a used one will a 92 work on the fast 90?
Old 05-01-2012, 09:39 AM
dodson55's Avatar
if you port the opening of the fast 90 then a 92 will work it will bolt on the way it is but it will just have a lip on it that will disrupt airflow
Old 05-01-2012, 11:18 AM
andy-lswon's Avatar
I'll try to find a 90. Anyone k.ow who sells new ones or will I have to find a used one
Quick Reply: fast 90 vs 92
