Exhaust question - I searched
Old 05-09-2012, 08:49 PM
simplysix's Avatar
Default Exhaust question - I searched
So I searched but still can't find an answer.
Im looking at changing my exhaust set up.
I was looking at maybe tsp true duals, but I can't figure out if it attaches straight to the lt's? Is there anything else in between?
Also, has any just used a H or X pipe with a straight muffler on each end and then dumped before the axle? Could that work or would it be to long?
Old 05-09-2012, 10:24 PM
The Scammer Hammer
dr_whigham's Avatar
https://ls1tech.com/forums/generatio...-pics-too.html
I truly believe all your questions will be answered right here
Old 05-09-2012, 10:29 PM
simplysix's Avatar
i did look through there, but it is a 50 page thread. It looks like from what i can tell, tep true duals mount straight on the headers, but i wanted to be 100% sure before deciding to order anything.
Old 05-09-2012, 10:31 PM
The Scammer Hammer
dr_whigham's Avatar
As long as you have LT headers, they slip right on and come with everything needed for install.
Old 05-09-2012, 10:32 PM
fucter's Avatar
yes, they mount to the headers
Old 05-09-2012, 11:22 PM
simplysix's Avatar
awesome, that what I thought but wanted to make sure. I already have LTs but they are some cheap/crappy ones that were already installed when I bought the car. I wanna switch to some nice 1 7/8's and do the duals at the same time
anyone have input on the whole torque arm thing. whats the easiest/least expensive set up to run TSP duals?
Old 05-10-2012, 04:02 AM
bww3588's Avatar
With your "cheap, crappy" headers, you may have to do some modifications. They are made to hook up to tsp, jet hot's and hookers I believe.
Old 05-10-2012, 04:03 AM
bww3588's Avatar
The stock torque arm will clear the duals fine.
Old 05-10-2012, 04:46 AM
The Scammer Hammer
dr_whigham's Avatar
And Pacesetters.
Sounds like you might have the eBay's... wasn't aware of that. I have no idea if they'll fit or not.
Old 05-10-2012, 10:21 AM
simplysix's Avatar
Yea, I plan on switching to the TSP 1 7/8 at the same time
I thought it had to be relocated.
Old 05-10-2012, 03:50 PM
bww3588's Avatar
Gotcha on The tsp headers...good choice.
My tsp duals cleared the stock torque arm just fine. Only made contact with the car on a lift and the suspension totally unloaded.
Keep in mind, they are not simply bolt on and go. To get the great ground clearance and fitnemt I did, it took some trial and error. Nothing hard tho just tweaking of hangars, clamps and positioning.
Old 05-10-2012, 06:56 PM
simplysix's Avatar
That's awesome to hear, thanks!
Old 05-10-2012, 07:07 PM
bww3588's Avatar
I'll post up some pictures tomorrow morning when I get off of my ground clearance.
Old 05-10-2012, 07:36 PM
simplysix's Avatar
