TA rear end cover leak
Prolly not the right place for this but I have a TA rear end cover and noticed there is a leak coming from one of the black pieces on the outside if anyone knows what I'm talking about. Seems to only do it after driving and reaching operating temperature. How would I stop this from this location?
I gotcha yah...Those are the load bolts. Is one loose? You should be able to hand tighten if they are loose...Do not get medieval on these! Torque to 5LBs..Then make sure that jam nut is snug to keep them locked in place. (the load bolts are in the center of the jam nut)
Edit: after re-reading sounds like just the jam nut may be loose..check both load bolt and jam nut.
Do you know if the bearing cap stud kit was actually installed? The black nut is the jam nut, that bolt in the center is load bolt. You can check that jam nut with a wrench, it needs to be snug. I would loosen the jam nut and check the load bolt with torque wrench, then snug that jam nut back down.
EDIT: If that does not work the thread seal may be trashed, if the leak is a little leak, then I'd leave it be.
good write up on install university
http://www.installuniversity.com/ins...id_install.htm
On the load bolts, I can't tell now with it on the car, I have two extra bolts that came with the cover. Do these go in the center of the jam nut? It looks like it already has two gold colored bolts there but just trying to make sure I get this right
