is this a decent air mass sensor as OEM replacement?
Old 06-03-2012, 02:38 AM
badmfkr's Avatar
Default is this a decent air mass sensor as OEM replacement?
Thanks
http://www.partsgeek.com/catalog/199...ss_sensor.html
Old 06-03-2012, 10:14 AM
JaYZeig's Avatar
in all honosty, i would not cheap out on a mass air flow sensor.
ive seen quite a few vehicles with aftermarket maf sensors fail after just a year of having them. even in gm training class they told us thts one thing not to cheap out on.
jmho
Old 06-03-2012, 11:31 AM
DaFireMan's Avatar
Just get a truck 85mm mass! they work great with minor tuning
Old 06-03-2012, 05:14 PM
HoLLo's Avatar
Definitely stay with an OEM type MAF sensor. Don't try and run any aftermarket ones, they seem to all suck.
Old 06-03-2012, 07:30 PM
sjsingle1's Avatar
you can move up to a GTO plastic maf......i did
Old 06-05-2012, 08:28 AM
badmfkr's Avatar
the GTO plastic MAS sounds good.
?1.what year GTO doe's this MAS come off? I'm thinking it has to be a early GTO w/ LS1 engine.
?2.where did you get it and what was the price please includ link.
?3. is addtionale tuning required or is this a direct replacement?
Thanks
Old 06-05-2012, 02:57 PM
sjsingle1's Avatar
delphi pn 64-1503
got it off ebay
the pn may have changed..... dont know if it needs tuning i have *NOT* tuned it
if you go to the dealer and get a maf replacement they are no longer metal
Old 06-06-2012, 06:05 AM
badmfkr's Avatar
Default is this the new GTO MAS?
it appears to be reengineered on the inside.
in the discription it fits many GM vehicals including the 99TA
Thanks
Attached Thumbnails is this a decent air mass sensor as OEM replacement?-mas1.jpg   is this a decent air mass sensor as OEM replacement?-kgrhqzhjboe-c4f1ewcbpvekfktug-60_57.jpg
Old 06-08-2012, 09:33 AM
badmfkr's Avatar
sjsingle1 are you there still waiting on you response
Old 06-08-2012, 12:22 PM
sjsingle1's Avatar
that looks just like mine....its a 5 pin but comes with a adapter....the air temp is better in the front location i think
Old 06-18-2012, 06:22 AM
badmfkr's Avatar
Default why is car constantly rueining MAS
I really don't like to use cheap auto parts however
I was in a bind so I ended up purchasing the cardone MAS SES light dissapeared.
1st MAS lasted 50 miles then the same P0171-P0174-P0300 codes came back.
2nd MAS lasted 25 miles then the same P0171-P0174-P0300 codes came back.
3rd MAS lasted 15 miles then the same P0171-P0174-P0300 codes came back.
can't understend why
there is no vacunm or exhaust leak, good fuel preasure new fuel fliter, clean air fliter. I'm at a lose on what could be going on.
Thanks for any advice
Old 06-18-2012, 08:16 AM
ramairetransam's Avatar
Maf maf maf
Old 06-18-2012, 08:22 AM
2win_SS's Avatar
^^^^ +1! I would go with a truck MAF(85mm) or a Z06 MAF... I know there is a sponsor out there that has a good price on one... Goodluck.
Old 06-18-2012, 09:29 AM
sjsingle1's Avatar
its always a crap shoot with reman parts
Old 06-18-2012, 12:30 PM
badmfkr's Avatar
Originally Posted by ramairetransam
Maf maf maf
is'nt the MAF and the MAS the exact same thing. the part just before the throttlle body.
will the Z06 MAF require additionale tuning?
Thanks
these cardones can't be complete turds that only last a few miles?
I'm changing MAS MAF more often than I check my oil.
Thanks
Old 06-18-2012, 01:38 PM
The Scammer Hammer
dr_whigham's Avatar
Kinda surprised no one has PM'd you with a stocker for sale. I picked up an extra one, low mileage, off here for this exact reason.
"Z06" or 85mm truck MAF (same thing) WILL require tuning.
Quick Reply: is this a decent air mass sensor as OEM replacement?
