Tell me everything i need to know for tsp headers and td install!
Title says it all I'm finally getting it done tomorrow after they've sat in my spare bedroom since October lol. Im worried about the stock tunnle brace and figuring out how to connect the hangers without messing up my car. Anyone with pics or any info will help
As far as the headers go, you'll be jacking the motor out of the driver side mount, as well as disconnecting the steering shaft. Passenger side is fairly easy. You'll have to get the car's nose about chest height (at least, I'm 6 ft for reference) to get these in. Obviously it's to your advantage to use a lift if possible. If you haven't changed plugs and wires either, do those while you're in there.
Tunnel brace may as well just be decoration. Its too light/flimsy to benefit chassis stiffness anyway. I dont have it on havent lost any sleep about it. Consider it weight reduction.
Is there a tunnel brace that works with this system or should I just not use one at all? And I'm gonna be getting some subframe connectors and need some that'll fit with the tds. So which tunnel brace and subframes should I go with
The Scammer Hammer
Don't worry about a tunnel brace.... but if you REALLY want one, MWC has a NICE one that tucks the best that I've ever seen. It has a driveshaft safety loop built in as well. I "believe" its 95 shipped.
https://ls1tech.com/forums/suspensio...l#post16121049
Notice how nicely it tucks?
