where is the best spot to weld a wideband bung?
Old 06-26-2012, 10:54 AM
SStressin's Avatar
Default where is the best spot to weld a wideband bung?
right now mine is in my y pipe.. is it better to put it right after the 02 sensor in the header?
Old 07-02-2012, 10:22 PM
SStressin's Avatar
bump...where does everyone put theres?
Old 07-02-2012, 10:42 PM
bestlude's Avatar
i put mine next to the collector on my driver side longtube header.. From my understanding, the driver side (bank) runs leaner than the passenger side and is alot safer to run the wideband there..
Old 07-04-2012, 01:01 PM
LS1 Racing's Avatar
Mine is right in the middle of my X-pipe.
Old 07-05-2012, 09:08 AM
thunderstruck507's Avatar
You want it as close to the header as possible in whichever bank runs leaner. On a fbody that should be the drivers side IIRC.
Old 07-05-2012, 11:27 AM
Moderator
jimmyblue's Avatar
Mine is in the I-pipe by the trailing edge of the passenger's
door. I don't want to see one bank or the other, but both.
Old 07-05-2012, 11:53 AM
SStressin's Avatar
right now mine is in my y merge. i was just wondering if thats a good spot where i could tune it
Old 07-05-2012, 12:52 PM
conan's Avatar
Thats where I put mine as well. No problems here, it's been right on with the dyno jet wide band the tuner sticks in the tail pipe.
Old 07-05-2012, 04:04 PM
LS-ONE_DAY's Avatar
ARH welded mine onto the drivers side collector I believe
Quick Reply: where is the best spot to weld a wideband bung?
