anyone have a CAI on a dd?
I would get the SSRA over the other ram kits I've seen...
You can cut out a plate to cover the opening when it's raining...
Put the plate under the filter wher the opening is to protect engine from water getting in
Ya would have to have your car sub merged! Lol... One ugly puddle can throw a good amount of water in there...
It's never happened to me but I've read threads about Hydrolock caused by ram air kits throwing water in the intake...
Read some threads about it
The Scammer Hammer
OP, I run a chrs1313 non AC ram air kit. Its completely sealed from the bottom of the scoop all the way to the lid. The rain **** is ridiculous. Just yesterday I drove 168 miles from Fourchon (pronounced Foo-Shawn) Louisiana to Lafayette LA in an ungodly storm. I couldnt even go 40 miles an hour.
There's no plate needed for it or anything. You HAVE to seal the front of lid anyways to take advantage of the high pressure effect. The kit's track proven, and a breeze to install. Trust me, you can't go wrong with it.
FYI, the SSRA has an opening right in the middle where the upper and lower piece fit around the metal support bars so I wouldn't worry about the water very much, and unless you seal it up with the rubber seal they supply with the kit you'll still be drawling air at the front of the air box. I like the SSRA it's a very durable quality piece.
I've had the SLP "Ram Air" and now I have the Fast Toys Ram Air and there's no possible way to get water up there, I don't see how you could ever do it. I've never had any rain issues with mine. I would never spend the prices companies are asking for them though. I bought my SLP and Fast Toys in the classifieds
Mark you know how much I like the SSRA and I think you saw my thread with track gains. Well worth it imo BUT like I said before I wouldnt wanna chance it in the rain. Sure, iv been caught in massive rain storms with my cars with ssra and nothing happened but you dont wanna chance hydrolocking. Especially since you just put that motor in! My advice is the same is before...get a cheap *** beater car for commute and save the toy for when its nice out
yea ik its happened but i find it hard that it wasnt some freak accident with a huge puddle. its not like the motor will suck in enough air to actually pull water up the 2 feet or how ever long the intake is.
Moderator
I believe you could get the same benefits with a steak knife and some
weatherstripping.
The steak knife is for the foam that obstructs the "nostrils" in the
Camaro front bumper that feed into the space above the radiator
divider panel.
The weatherstripping is to make sure the airbox opening draws only
from that nose pocket and not a blend with the engine bay air. With
the nose pocket air path relieved, the air above the divider panel is
better than the air below, especially when you've been sitting.
The problem with IAT heat soak is related but has a better solution.
My cold air system has the SS hood and a hacked CAI that pulls from
above instead of below. Air temps are good. When the CAI was as-
original, it raised my air temps over where the SS hood had them.
The stainless SLP one is a bad idea except for its structural quality.
Thermal-wise it sucks.
I also do not shroud my radiator one bit.
weatherstripping.
divider panel.
