fast 92mm ... need help
I am putting on a fast 92mm intake on my 99 Camaro SS... i know i need to buy LS6 coolant pipes... can i get from a dealer? what else will i need?
Go thru TSP^^^
http://www.texas-speed.com/p-1308-co...sx-intake.aspx
You will need button head bolts for the valley cover. Mandatory.
Goodluck on swap!
Goodluck on swap!
you can use the stock ls1 coolant lines with some careful bending.some people use 2 ls6 coolant lines,1 for the front and 1 for the back of the heads.you run a line to the front 1 and connect them .
