God forsaken governor...
No properly running V8 (LT or LS) should be bucking at 118mph. Do you have a V6? If you have a V8 something is probably broken or needs replaced. Mine doesn't buck, it get a little floaty around 135mph, but it would smoothly reach 155.
Why do people have to answer when they don't know the answer???
If the car came with non Z rated tires, the speed limiter is indeed set at 118mph. It has to be tuned to change it. I think a handheld tuner can change it but I'm not sure. A person/shop with tuning software can change it for you. With Z rated tires, the speed limiter is set at 162mph.
Pardon me, from now on the whole board will wait for you to revel us in all your knowledge
Seriously though, I was unaware that Z28's came with 235's as the basic option until I found a post that broke it down.
So while you are probably correct in this case, no need to be a dick about it
Z28-standard P235/55R-16 Touring,Option P245/50ZR-16 Performance,Option P245/50ZR-16 All Season Performance
For further reading on your issue OP, a similar thread was started a month ago I just found
https://ls1tech.com/forums/pontiac-f...d-limiter.html
