Nick Williams 92 to Fast 92 intake
I need help with getting the correct size mounting bolts that connects the tb to the intake? I thought the tb would come with the bolts but it didnt. Thanks in advance
put the o-ring on the intake, hold the throttle body against the oring / intake like you are installing it. Get a tape measure and measure the distance that the bolt needs to prodtrude through all materials. Then add in the thickness of 2 washers and a nylock nut to your previous measurement.
Now with this new measurement, go to a hardware store and find a bolt that has that dimension that you just figured out. Only measure the bolt length under the head. Do not add in the bolt head. Now add another 1/16" in length to account for wanting the threads to prodrude through the nylock nut for a correct fit.
now you have what you need. No need to wait for shipping, these bolts are at every hardware store. You can even get stainless.
BlackDuk thanks from the info...I was hoping someone knew the measurements already cus I'd have to find a tape measure.
Go on 3, yea that was the plan to go to home depot
