weird oil leak, changed everything, pic
Old 11-22-2012, 08:31 AM
vbls's Avatar
Default weird oil leak, changed everything, pic
ok, i have so far changed oil pan gasket, valley cover, valve covers, rear main, all new intake, knock sensors, rear cover gasket. the funny thing is drips a few drips when i shut the car off, not when i drive. 130,000 miles. its a little on both sides of the block.
Old 11-22-2012, 08:55 AM
mischief's Avatar
Did you check/change the oil pressure sending unit behind the intake?
Old 11-22-2012, 09:18 AM
vbls's Avatar
i changed that when i changed the intake, because i broke it. just swap them out is all right?
Old 11-22-2012, 09:50 AM
mischief's Avatar
Usually, but there's also a chance of breaking it on installation too.
Old 11-22-2012, 10:19 AM
vbls's Avatar
its really getting to me, i have no idea
Old 11-22-2012, 10:51 AM
superbean's Avatar
That's what I was thinking.
Old 11-22-2012, 02:26 PM
therabidweasel's Avatar
Did you put a little rtv in the corners of the pan gasket where it joins the rear cover?
Old 11-22-2012, 03:33 PM
RsSean's Avatar
I seen the flex plate/flywheel bolts leak thur the threads. Then it appears like that, or that oil cooler housing above the filter
Old 11-22-2012, 10:01 PM
AutomagicLS1's Avatar
unless I missed it did you change the oil cooler block off plate's gasket also? Looks like its leaking just above the filter had it happen to me
Old 11-22-2012, 10:05 PM
Ferocity02's Avatar
Ditto
Old 11-23-2012, 04:36 PM
vbls's Avatar
is that the piece right above the filter with 2 bolts in it?? how do i fix that?
also i did use rtv in the corners of pan and also the flexplate bolts are ARP and brand new cause i just did a converter/flexplate
Old 11-23-2012, 04:51 PM
edwardzracing's Avatar
Take the two bolts out, pull the cover off and replace the gasket that's under the cover. Then put the cover back on. Hopefully you can find the gasket at a local parts store.
Old 11-24-2012, 06:46 AM
vbls's Avatar
will a bunch of oil come out??
Old 11-24-2012, 07:15 PM
kyleholt11's Avatar
Not a bunch but some will. My motor was leaking from there as well as the crank sensor (which is by the starter). I was getting a few drops of oil after I shut the engine off as well...
Old 11-25-2012, 01:22 AM
not much. the seal is like $10 at the dealer and I just found one for $4 bucks on ebay. The oil you are seeing on the other side of the motor is probably from the flexplate fanning it that way
http://www.ebay.com/itm/LS1-LS6-LS2-...af3552&vxp=mtr
Old 11-25-2012, 11:23 AM
vbls's Avatar
ok i changed it so i will see
Old 11-25-2012, 02:01 PM
Grifter's Avatar
I would suggest adding oil dye to the engine, it should allow you to pinpoint the leak pretty easily.
Old 11-26-2012, 05:24 AM
vbls's Avatar
where do you get that from
also if its up above like behind intake or something like that you wont be able to see it
Old 11-26-2012, 11:41 AM
Grifter's Avatar
If you can't find it at a local parts store any GM dealer will have it.
You'll need a black light to be able to see the dye in the oil. Some guys don't use a black light, I can never see it without one. Even if it's behind the intake you'll be able to follow it up and find where it's leaking from. This may involve removing the intake or other parts to locate it but it's better then throwing parts at it and hoping it'll fix it.
Old 12-18-2012, 08:04 PM
senicalj4579's Avatar
any luck? I have a leak that looks like that
Quick Reply: weird oil leak, changed everything, pic
