header/mm install, steering shaft problems
ok so I completed the dreaded header/mm install today, was able to do motor mounts without removing any accessories and with minimal problem (removed entire pedestal as many have suggested) but on the drivers side when I went to reinstall steering shaft linkage assembly that i removed completely to slide in drivers side header the shaft is hitting against the #1 primary and not allowing the linkage to be reinstalled correctly.
Ive read that you can move the entire steering column over to aid this? or is this only for lt1s? the primary is hitting the actual shaft, not any of the knuckles, i would need maybe 1/2 an inch to an inch
could i ground down shaft diameter? maybe aftermarket thinner steering shaft? thanks for the help in advance, only thing holding car back from being on road
anyone know if i can move steering column over with the two slotted holes the people over on lt1 boards use?
or maybe steering linkage extensions? trying to avoid shaving the diamter of shaft down
this might be the problem as the angle does seem a little too vertical, how could i tell if it is v6 rack or the correct v8 rack? if i posted a picture would you be able to tell me? any code i can look for? location? i know i can find which was supposed to come with it on door, but how would i know if its been replaced before?
ok, so i am leaning towards the v6 rack idea since when i removed the pedestal for the drivers side motor mount, there was an area on the pedestal where you could tell that the steering shaft had been touching it as well as points on the shaft that showed rubbing problems against pedestal, i dont know for sure but I can imagine this is not normal at all, the steering also felt somewhat iffy before and im pretty sure i can attribute it to this rubbing between shaft and pedestal
here are some pictures of my current situation with header and shaft and pictures of rack
in this pic you can see the bottom of steering shaft and how it wont go in, the header blocks shaft from moving over enough to slide back in, this is with top of shaft secured on column
steering rack
can anyone identify it as v6 rack? ideas?
steering rack
The.angle between the two.racks is hard to notice without them being side by side. So if someone can tell from a picture id be surprised. There is a part number on the rack you can get and look up. I can't remember if you can see it or not.while its bolted in however. Ill check mine later
I am definitely not able to tell from pictures and looking at it in car, plus im pretty biased since it would fix my problem
if anyone has the more angled version for sale let me know, might aswell buy it and try it out
http://www.bildelsbasen.se/?link=item&post_id=21718867
that is the rack i find when i search the part number i got off my rack, which definitely looks like the less angled version, so for anyone with header clearance problems with steering shaft, check your steering rack!
