magnaflow dual setup????
Old 03-16-2013, 07:02 PM
bigantws6's Avatar
Default magnaflow dual setup????
I'm trying to quiet my car dwn I'm tired of my bullets I'm running dials so I wanted to run magnaflow stainless straight thru exhaust and want to see what yall running with a dual setup with dual tired of the load exhaust
Old 03-17-2013, 09:08 AM
gMAG's Avatar
I have Magnaflow duals, and like the sound very much.
Do you have a sound clip?
Old 03-18-2013, 12:16 PM
bigantws6's Avatar
no what is that how did u run your muffler
Old 03-18-2013, 03:18 PM
gMAG's Avatar
Is this what you're looking for?
Old 03-18-2013, 09:03 PM
bigantws6's Avatar
Yea is that a 60s model camaro I'm trying to fit on a f body
Old 03-18-2013, 09:18 PM
gMAG's Avatar
Yes, as in my signature.
The kit was made for 1st gen f-body. There was a bit of tweaking required.
Magnaflow might make a kit for yours.
Old 03-18-2013, 11:36 PM
slow ride 02's Avatar
Thats a big no. They only make a single 3" Rasp Back System for the 4th Gen Camaro.
Old 03-18-2013, 11:52 PM
gMAG's Avatar
If you want the sound, then buy the x-pipe & mufflers, then have someone build the pipes.
Old 03-19-2013, 09:13 AM
Blackpanther99's Avatar
^Agreed, just buy the stuff you want and let the muffler shop do the fabrication. Magnaflow does quite down the sound a bit compared to other exhausts.
Old 03-19-2013, 10:45 AM
gMAG's Avatar
This is a cold start...it is about 20 degrees F.
Idle is at 1100 rpm. At 20 or secs, idle settles to 800. At about 43 secs, you'll hear the ECM switch over to closed loop, which takes about 14 secs. Later, rpms are held at 2000 for a few secs. Then, a rev to 3000, & also to 4000.
I was hesitant to go farther, as the block was still cold, & oil pressure still high @ 70
While the sound is quite full from the camera's position, it is subdued from the cabin, even with windows open, until under acceleration.
With the Magnaflows, I wasn't 'vibrating' for half an hour, after taking a spirited drive.
Listen with a headset to get the true sound.
Old 03-19-2013, 01:31 PM
bigantws6's Avatar
Sounds real good man I want mine like that since mine is crazy loud
Old 03-21-2013, 01:39 PM
Redbirds's Avatar
They definitely make two. One with two tips, one with four.
Quick Reply: magnaflow dual setup????
