Power Bond and SLP Pulley / Summit Tool
Old 08-16-2013, 01:42 PM
badazz81z28's Avatar
Default Power Bond and SLP Pulley / Summit Tool
Hey all,
I just wanted to put this one to bed because quite a few people have been curious to know according to my archive search.
The SLP Pulley IS a re-boxed Power Bond. No question about it...the Pulley has PowerBond's Logo and part # right on it!
AND the SLP 100221 (LS1 F-body) and 100226 (LS1/LS2 GTO) ARE the same pulley. They are both engraved with PBU1480-SS25
Also....I tried Summit Racing's house brand of the pulley installer! WOW! Worked great and better than the HAWK tool. Its long enough that you don't have to adjust it!
Old 08-16-2013, 01:56 PM
BlackBetty99SS's Avatar
Cool, thx for the info been looking into replacing my balancer but just been putting on back burner til the weather is nicer here.
Old 08-17-2013, 12:25 AM
01ssreda4's Avatar
Whats long enough you don't have to adjust it? I'm not following. The Hawks tool is as simple and as well made as you could ever ask for. What makes Summit's tool "better"?
Old 08-17-2013, 10:55 AM
During installation with the hawk tool with press/bearing backed all the way, you can only thread it into the crank so far. I had to press the pulley partially on then re-adjust to thread the rod further into the crank so I didn't pull the threads. The summit tools threaded rod is longer. I could thread it into the crank all the way from the beginning. Both tools are great, but the summit tool was cheaper and a little better from a user prospective. I bet you could even use it on the ls7 which hawk has a separate tool for
Old 08-17-2013, 12:36 PM
RezinTexas's Avatar
interesting, I do not recall having to do that with my hawk tool and OEM truck crank pulley.
Old 08-17-2013, 12:44 PM
The Hawk tool works, but I didn't want to pull the threads out of my crank. I didn't feel comfortable with the thread engagement of the Hawk. Once I had it on far enough to expose more threaded rod, I re-adjusted.
Old 08-18-2013, 12:16 AM
01ssreda4's Avatar
My Hawks bottoms out in the crank and is exactly the right length for my Powerbond. That's why I thought your post was odd.
Old 08-25-2013, 11:33 AM
Well went to the track yesterday and gained 1/10th and 2 mph. Only Change was the pulley!
Old 08-25-2013, 04:16 PM
manzo81maro's Avatar
nice gains! I never got to the track after I installed my powerbond UD pulley, but definately noticed quicker reving and throttle response...I made my own tool for about $30, using M16 x 2.0 all thread, some nuts, washers and a spacer...works like a charm
Old 08-26-2013, 12:17 PM
JJsQwuik's Avatar
curious on whats the part number on the summit tool???
Old 10-20-2013, 10:12 PM
http://www.summitracing.com/parts/sum-900135/overview/
This looks long enough for both LS1/2/3 and LS7.
Quick Reply: Power Bond and SLP Pulley / Summit Tool
