exhaust question about mix and matching
picked up a firehawk for my 3rd ls1, and i love it except for the slp loudmouth ll system on there. i have the bbk long tubes with bbk ORY, then converges into the slp system. the tone is quiet at idle and at WOT seems to be mostly all rasp. my question is could i get just a muffle from some other system say GMMG or flowmaster/borla/etc and remove the slp bullet and put the muffler in its place or would the whole system need to be removed and another system installed
I would say try replacing the SLP loudmouth muffler. I would say keep the SLP piping because it is stainless steel and mandrel bent and replacing the muffler is cheaper. Possibly, like stated above, try a good merge too. Looking to do the same setup your car has and changing the muffler when I finish my engine swap.
Yes you can remove the LMII muffler from the intermediate pipe of your exhaust and put another bullet muffler with a similar length and 3" inlet/outlet and it will work just fine. That's what people do when they say that they have a "Borlamouth". It is the SLP Loudmouth catback with a Borla XR1 swapped in where the old LMII muffler used to be. People seem to really like the Borlamouth a lot more than the original Loudmouth catback once they put longtubes in there. It will rasp LESS too.
OP I had the same thing as you basically, but with the LM1...talk about loud and raspy lol!! Had a Flowmaster merge welded in with a Magnaflow 14419 bullet muffler, and it killed almost all the rasp, and has a much deeper tone
ok so heres the plan so far, id like to pick up one of the flowmaster merge y pipes, and a single borla xr-1. now with my current setup being the the bbk longtubes and the supplied 2.5 inch ORY, does anyone see any issues with fitment or install? any paticular size xr-1 in length or width? and how about the flowmaster merge? do they offer a 2.5 in and 2.5 out?
+1 for the Magnaflow bullet muffler. I personally did the dynomax bullet, but it still has a lot of drone at certain rpms (which I don't mind). Magnaflow bullets always sound good though especially with a proper merge.
Here is a pic of it under the car:
http://i91.photobucket.com/albums/k2...psc5fbbc59.jpg
Just swap your LMII muffler with this or a Magnaflow and that's all you have to do.
IMO, spend a couple dollars more(+$5) and get the 409ss FM Y250300S. I'd also wouldn't hesitate to cut the exit end of the FM merger down shorter since it's fairly long.
http://www.summitracing.com/parts/fl...300s/overview/
I cut the original LM1 muffler off of my system and had a pair of Moroso Spiral Flows welded into the system just before the exhaust tips. With 1 3/4" LTs and custom Y pipe with the Flowmaster merge it sounds great on a mostly stock car.
