LS1 intake..is mine junk?
Old 07-06-2014, 07:59 PM
nascarnate326's Avatar
Default LS1 intake..is mine junk?
Trying to troubleshoot some kind of idle problem/vacuum leak. I decided to take the intake of my car and see if the map sensor was as loose as it felt.
I found this:
Sooooo....is this thing junk? I knew it was ported by the previous owner but I guess I never really thought they would have cut the bottom out and glued it back together.
Old 07-06-2014, 08:33 PM
2xLS1's Avatar
Wow is all I can say.
Old 07-06-2014, 08:52 PM
mikesimpalass's Avatar
I would never trust that, looks like a perfect time to upgrade to a ls6 intake
Old 07-06-2014, 09:03 PM
Shuckman00's Avatar
I have to agree with the above comments. Wow I would be looking for a ls6 intake and never put that abomination back on. In fact I would put it in a barrel and burn it with gas a lot of gas.
Old 07-06-2014, 10:03 PM
poltergeist 02's Avatar
Thanks for that. I just spit my drink all over my computer.
Old 07-06-2014, 10:39 PM
Root2812's Avatar
Cut it back out and save that MAP port. You can then score a cheap LS6 intake with a busted MAP port. Cut the busted MAP port apart to safely remove it from the LS6 intake and then pop in your good one. Might save you a few bucks but yeah that intake you have should be tossed out.
Old 07-06-2014, 10:52 PM
Majestic9C1's Avatar
da ****?????
drop kick that thing into the dumpster
Old 07-06-2014, 10:55 PM
99Bluz28's Avatar
Good point!
Probably the only thing you could possibly salvage from it!
The stuff people do and then even think it's acceptable never ceases to amaze me!
Old 07-06-2014, 11:01 PM
99Bluz28's Avatar
That intake is JUNK!
If you don't mind running a aluminum intake manifold then also consider a BBK SSI intake manifold, since a used one will normally run less the a used LS6, and the same with comparing new/new.
Old 07-06-2014, 11:19 PM
99 ss's Avatar
There might be someone who will buy it from you lol no
Old 07-07-2014, 08:00 AM
LS1-450's Avatar
Actually, someone may buy it, to use for mock up or to practice porting.
OP, if you want to keep it, gring some of the filler down so you can find the leak & re-seal it with a marine grade epoxy like splash zone. That intake is repairable if you choose to keep it.
Old 07-07-2014, 08:53 AM
big hammer's Avatar
lol wtf??
Old 07-07-2014, 10:00 AM
LS1MCSS's Avatar
That has to be the worst looking mess I have ever seen. I would just have to post the name of the person who did that ****.
Old 07-07-2014, 12:58 PM
Sadly I dont have the name of the person. I know they used a lot of information from this site years and years ago to do this. Most of the modifications were done in 2000-2001 from what I have been able to tell. It came with lots of documentation.
That being said, its been working reasonable well for a long time it looks like. some how.
Anyone got a intake for me? lol
Old 07-07-2014, 05:14 PM
99Bluz28's Avatar
Here's the lowest price I could find on a new BBK intake manifold.
http://www.ws6project.com/user_stor/...take-manifold/
If you want it in the new black finish:
http://www.coloradospeed.com/bbk-ssi...6-p-30502.html
Old 07-07-2014, 10:26 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Yeah, toss that mess.
Here's the real thing: http://www.ebay.com/itm/ls6-intake-manifold-/221486942532?pt=Motors_Car_Truck_Parts_Accessories&hash=item3391a68944&vxp=mtr
Old 07-08-2014, 02:43 AM
Burken01's Avatar
Damn I thought I've seen it all till now!
Old 07-08-2014, 02:31 PM
Fourth-Gen Man's Avatar
"Welp...... I think I've found the problem ma'am"
Old 07-08-2014, 02:46 PM
After looking into it more it appears they used JB Weld of some kind for the first "seal" then went over everything with the orange/red gasket material from Permatex. Hooked a leaf blower up to the font of the intake, couldnt feel any leaks.
Im going to try using it for the rest of the season and then try to get a FAST when my motor is rebuilt/cam this winter.
Old 07-08-2014, 04:07 PM
idahoz28's Avatar
That's A Nice One......
Quick Reply: LS1 intake..is mine junk?
