Oil Pressure Gauge - Sender Size?
Installing an LS2 into a BMW. I going to use an Aeroforce Interceptor to monitor most engine parameters (via OBD2) but I'd like to install a proper stand-alone aftermmarket electric oil pressure gauge.
Are all of the senders the same size? I plan to install the aftermarket sender in place of the stock LS2 sender, at the rear of the intake.
Looking at this Speedhut gauge. Others to consider?
TIA.
Tipsy
TIA.
Tipsy
Usually 1/8" NPT is the norm for aftermarket gauges. I bought a replacement cooler block-off plate that has a 1/8" port already in it. $15 on eBay..search for "LS2 OIL BLOCK" or similar. Or if you want to adapt the factory end of things, look for something like this:
http://www.autometer.com/cat_accesso...il.aspx?vid=58
Good luck.
Good luck.
Good luck.
Good luck.
What I'm wondering is, are all electric oil pressure senders are created equal with regard to size? It's pretty tight behind the intake manifold. I like the Speedhut oil pressure gauge (it's full sweep) but I'd choose another if there are smaller senders available.
Tipsy
