Dorman ls2 intake?
#42
The Scammer Hammer
If this is indeed LS6 runners with a 90mm TB, Dorman is gonna have issues keeping it in stock. Even the guys with stock LS2 intakes (HORRIBLE RUNNERS) will be chucking theirs in the trash.
#44
90mm TB. Hell no the LS1/6 rail won't fit. It's made for the LS2. Do you see any long-line-dimple going across for the fuel rail?
#48
#52
The manifold is the same body as our 615-900 Manifold. Fuel rail brackets are included in the kit to accommodate the LS2 Fuel Rail. Instructions will be included for any specific requirements. The part number has been blacked out for the time being until part is released.
#53
The GM LS2 Stock intakes suck ***!
#57
Will the doman replacement a direct bolt on to the ls1 intake found on 99 z28s and is there any comparos with the ls1 intake? is it worth it to swap for a cam only car ?
When ls2 released will it fit the ls1?
#58
For those that may be wondering , that port and post on the snout is the map sensor location , I do not know if there is a option to locate at the rear of the intake. As for release date I tried to tell you guys that this LS2 was not going to happen in October or even November 1st as mentioned in earlier post ..... but my source says it may still be ready in December but more likely January.
