oil filter relocation opinions please
Old 09-29-2015, 09:42 PM
camarozz383's Avatar
Default oil filter relocation opinions please
has anyone tried this kit? trans dapt 1120,
http://www.summitracing.com/int/part...1120/overview/
Old 09-29-2015, 11:38 PM
Spade's Avatar
What would be the purpose? Just curious.
Old 10-01-2015, 02:54 AM
I cut my base pan down as it was from a truck, so now I don't have enough oil volume, if I add the relocation kit and a bigger filter it should do it for me, not looking to break the bank so hoping this kit works!
Old 10-02-2015, 09:30 PM
unit's Avatar
"Trans-Dapt Performance remote oil filter relocation kits allow you to move your oil filter to a more accessible location, making filter changes quick and easy. They're available in single or dual filter kits. Dual filter kits double the filtration of your oil system to keep oil cleaner and add an extra quart of oil capacity." On the Corvette you could run a larger filter for more filtration or just to change just the filter in between oil changes. The average guy probably wouldn't want it but racers might find it useful.
Last edited by unit; 10-02-2015 at 09:32 PM. Reason: Quotes added to show this was from the Summit Racing advertisement.
Old 10-03-2015, 08:34 AM
That's MISTER MODERATOR
Paul Bell's Avatar
What vehicle are you using this kit in?
It's not listed for any modern LS engined vehicles.
Remote oil filters are a great idea. It removes the filter from header pipes and usually uses a larger filter, never a bad idea.
Old 10-03-2015, 10:25 AM
Spade's Avatar
Fair enough, I just never really thought about it myself. Have not seen anyone do it either but it does make sense with headers being right next to the stock location of the filter.
Old 10-03-2015, 08:39 PM
ended up going with this kit form derale performance, part# 15716, might add A cooler while im at it,
Paul bell, its going in my 89 camaro rs with a 5.3 LS swap, ill add a few pics and results when I get it installed, thanks guys
oil filter relocation opinions please-157164.jpg,
Old 10-03-2015, 08:41 PM
Paul Bell's Avatar
I like this kit better, it has a more substantial adapter that goes on the block.
Quick Reply: oil filter relocation opinions please
