Hooker aerochamber
Old 11-05-2015, 02:27 PM
VandykeT/A's Avatar
Default Hooker aerochamber
Anybody have any experience with a single in single out hooker aerochamber. I'm planning on running a 3" to 4" merge 4" cutout reduced back down to 3" and something similar to a Mufflex only a 3" system. Would the single aerochamber quieten the car down enough for a dd. I want the car pretty tame I just don't want tips.
Old 11-13-2015, 01:24 AM
Pontiacerator
RevGTO's Avatar
Don't have any experience with a single in/out Aerochamber, but I do with the Hooker Maxflow. The Maxflow killed rasp much better than the dual tip Aerochamber I tried. I would look into the Maxflow if I were you. You can do a search and find many of the posts that I and others have written about it. Quiet in normal driving and authoritative when you get on it. I have a 3" to 3.5" FM merge back to 3" similar to what you're planning.
Old 11-13-2015, 07:55 AM
01ssreda4's Avatar
The hookers are good mufflers.
Old 11-13-2015, 02:14 PM
VandykeT/A's Avatar
Maxflow is what I bought. Doing a 3 to 4 back to 3 with the maxflow.
Old 11-13-2015, 09:03 PM
omc8's Avatar
And why are you stepping down a full inch from 4 to 3 ?
Old 11-13-2015, 09:10 PM
VandykeT/A's Avatar
I'm gonna run the 4" cutout for flow and reduce it back to 3 behind it so it's easier to get over the axle and the 3" will be quieter.
Old 11-13-2015, 09:17 PM
omc8's Avatar
I was just curious, I would only step down to 3 1/2 . But let us know how that turns out for you
Old 11-13-2015, 11:38 PM
VandykeT/A's Avatar
I've got the same set up on my 408 ws6 just into a hooker catback. Only down side I've found to it is I need to open the cutout before I can run it hard. My tuner says it's not safe with the cutout tune and it not open. I've got a cable and he emailed me both tunes so I can switch back and forth. Hopefully this car won't have enough flow difference to matter on the tunes.
Old 11-19-2015, 04:46 PM
KingJacobo's Avatar
I had a Hooker Aerochamber catback for a year. Still have the catback in my garage.
It is QUIET, but has a nice rumble that my friends and I all decided sounded like a lion in a cage growling. Barely louder than stock. Flows very well though.
Old 11-19-2015, 04:53 PM
scotty2000ss's Avatar
I had hooker aero chamber on my camaro at one time. Sounded bad ***.
Old 11-20-2015, 02:05 AM
Exidous's Avatar
Sadly I have a SS aero chamber 3.5" sitting on my self waiting to go into my RX-7(been there for over 2 years lol). Don't know what it sounds like but EVERY opinion I read was positive. Great sound, no rasp and not too loud. It's just physically quite large.
Old 11-30-2015, 11:16 PM
customblackbird's Avatar
I just finished fabbing my exhaust. I run SS long tubes into Dual 3" mandrel sbends into a flowmaster dual 3 inlet to single 4" outlet. Then I run 4" over the axle into a hooker max flow then into a 4" dynomax ultra flow with a short turndown tip at the rear axle. I'm worried about sound being too loud so that's why I'm running dual mufflers. And the 4" case size is too large for my tranny tunnel. I don't see the point in reducing the exhaust after a cutout to control sound. Who wants to have to open it up when they want to get on it. I would just build the system correctly while not restricting flow.
I built my system for less than $300 and that's including both mufflers, all the pipe and mandrel bends, ypipe and all quality band clamps. I sold my custom 3" dual exhaust to build this kit to reduce noise, increase ground clearance and not limit flow.
I think it's important to say I was shocked to see the hooker max flow was made in China on the box when I received it. Dynomax in good ol USA.
Quick Reply: Hooker aerochamber
