Question about Extending Exhaust Under Axle
Hello everyone, I recently installed my TSP 1 7/8" LT's with the TSP Rumbler Dual exhaust set up. First things first, it sounds great! Can definitely tell the power difference. However, I am wanting to extend the exhaust out the back to get the more of the noise into the environment and not in to my interior. I have seen pictures of people going under the axle but I am concerned about how much space you need to give the axle so that it doesn't hit the exhaust when going over a bump. Anyone with under the axle exhaust experience I would love to hear your input! Thanks everyone.
Finally was able to find a bit of information on this. I might go a different direction and do over the axle. It will be more expensive but I think better in the long run. I'm lowered though, is there a kit to relocate the panhard bar for a lowered vehicle?
I had Texas Speed true duals that were modified to run under the axle and I ended up changing setups completely. Ground clearance wasn't great under the axle, although I never had problems going over small/reasonable sized speed bumps. I'm now working on a 4" single system.
If you go over the axle there is panhard bar relocation set-ups out there. That's how kooks true duals fit over the axle.
Honestly though, on my car with a decent size cam, running the exhaust out the back didn't do much for in cabin noise or fumes.
UMI has some great products for your car, I run them on EVERY piece of Suspension under my car. Plus they are red, matches my car!
Chad
I didn't like the way the tsp true duals sounded at all with the dynomax bullets, I switched to spintech pro-street and it sounded 100x better but I was still fighting ground clearance issues.
I would recommend just changing mufflers first if it's too loud inside, getting the exhaust run out the back is expensive and might bang/hit stuff as it's hard to fit big pipes over or under the axle.
There's lots of mufflers out there and it'd be easier and cheaper than modifying the whole back end of the system.
I should specify that I don't mind the noise so much as the drone that is entering the cabin and if I extend the exhaust it will give me room to put in an exhaust resonator tube to cancel out the drone! Also I think a couple shiny pipes out the back would look nice haha. Thanks for all the advice by the way.
Loser98 do you have any sound clips or vids of what your car sounds like with the new mufflers? I like the way my car sounds now but i'm not in love with it so much that I would be against changing mufflers haha.
No electric cutouts, just a sealed length of pipe that runs in front of your mufflers, length depends on what rpm range your drone is at.
http://www.performancetrucks.net/for...-drone-489463/
http://forums.corral.net/forums/gene...tely-gone.html
Edit: I just found a video of a man who installed these onto the end of electric cut outs so he could have the loud exhaust when he wanted or quiet for cruising
Resonators don't really do much in all honesty, it sounds to me like you need to change mufflers and go from there. It's gonna smell like raw exhaust at long red lights even if you run the exhaust out the back. I've had 4 exhaust setups and I like the spintech mufflers the best, they are loud though.
Big thing to realize is that these cars were not designed to have true duals.
