LS1 Block Missing Oil Pan Hole
Motor is a LS1 removed from a 2001 Camaro. I swapped the F-Body oil pan for a C6 LS2 pan to gain some ground clearance. The C6 pan has one more hole near the oil filter than the F-body pan, which has a vertical rib in that location. There is sort of a boss on the block that looks like it would accommodate a hole, but no hole drilled and tapped in the block.
I am really considering drilling and tapping a hole in the block there, I hate oil leaks. What do you guys think?
