New oil pan missing bolt hole or new normal?
I just ordered a new fbody oil pan and it appears to be missing a hole. Is there some reason its not drilled...or did they just miss it? I didnt want to drill it if there was some reason they stopped doing that one. Here is a pic:
I'm guessing here, but I say they missed it or it was a manufacturing flaw. That's a long run of gasket without a bolt to clamp it down. I bet it pours oil if you were to install as is.
Good luck with the resolution.
There is, which is why I was wondering if it was normal for that hole to not be drilled out. I should mention, I'm putting this pan on an ls2, not an ls1, so maybe there isnt a hole in that spot on the block on the ls1.
There must have been a change somewhere because my 2002 ws6 has a hole in the block but no hole in the original pan I took off. The new pan is the exact same way. The oil leak that I had was not from that portion of the gasket though. Interesting.
