Question about custom made Underdrive Pulley with pictures
While pulling out my engine from the car, my cousin saw the ASP underdrive Pulley I had, and told me if the LS1 was internally or externally balanced, so I told him it was internally balanced, so he said he will take my underdrive pulley and try to make the same out of aluminum in his workshop. So they made one exactly the same and it was balanced and zeroed i guess on the lathe machine. Now would this work if I used it on an LS1 or not ? What makes us worry is the ASP Pulley has 3 small holes that look like they are there for balancing(not the bolt holes). The custom one is also lighter. Just wanted to ask if anyone has tried something like this or I should not even be thinking about this as it might not be balanced right. My cousin made many of these for LT1s and small block 350s and they work great. What do you guys think ?
Mahmood
Mahmood
Mahmood
Mahmood
I wouldnt mind having someone testing it out if they agree that im not responsible if something goes wrong! Also, im not in the US anymore so whoever wants to try it would have to pay for shipping it from the middle east to the US. I could probably find some company that will ship it for a good price. Let me know if anyone wants to try it out.
And thanks for the compliments guys, my cousin has a pretty big workshop and they work on caterpillars, cranes, big trucks so pretty much anything they need can be fabricated right away!
Mahmood
Mahmood
Originally Posted by LS1BlackZ28
Is that one piece of aluminum? I know the ASP pulley uses a two-piece design, which kind of screwed them over a couple years back when the rings were flying off and imbedding themselves in radiators.
Mahmood
Harmonic DAMPER. It is not making anything wet or moist
You're right though. They are there to help quell crankshaft harmonics.
This could prove potentially harmful.
I'm tempted to give it a shot though .
I'll tell you now I doubt this will be effective as anything more than a pulley. I do not think it will adequetely control harmonics. Lack of mass and nothing there to counteract harmonics. Usually there is an elastomer strip separating an inner hub and outer ring or a type of fluid.
damp·en (d˛m“p…n) v. damp·ened, damp·en·ing, damp·ens. --tr. 1. To make damp. 2. To deaden, restrain, or depress: “trade moves . . . aimed at dampening protectionist pressures in Congress” (Christian Science Monitor). 3. To soundproof. --intr. To become damp. --damp“en·er n.
Either one is appropriate.
Originally Posted by Ryan Karasek
Also, it would need to be sleaved or the likely hood of spinning on the crank are greatly increased.
Ryan
Ryan
2XLS1- I thought the LS1 was internally balanced so it shouldnt make a difference or would it ? Also from what I understand the inner hub of the ASP is aluminum because its lighter whereas the outer ring is steel because aluminum will eventually eat up the belt whereas steel wont and maybe thats why they have steel on the outside. Correct me if im wrong please.
Mahmood.
Those look great - if you can resolve the crank harmonic issue you'll be golden.
BTW, your cousin does some nice work - those look great ! Have him make us up some valve covers, LOL !
Bad30th
Bad30th
