decarbonizing intake how often
Yes.
The catch can like it says is a container in which the oil and other residue dump into from the pcv line.
Basicaly PCV line to catchcan>>>catchcan to PCV valve>>> into your intake.
Search and read plenty on that.
Originally Posted by PREDATOR-Z
Seafoam AKA GM top end cleaner. If you don't have a catch can or LS6 PCV mod once every 3 month or so. (That is what I did untill custom catch can)
Personally i used to just clean my plugs with ether/gas after that. Then i would run some Red Line Fuel Inj cleaner and i was good to go. But I'm somewhat of a freak
I even change my oil once I don't like it's color anymore. The oil intervals set as a rule of thumb do not know how I drive my car.
Good blood means a healthy body
I've been cleaning the throttle body with Lucas fuel injector cleaner on a rag front part every oil change remove and clean rear & front every other oil change. add cleaner to fuel every 5k miles. will this be good enought or should I try the 3m kit that cost $35. is it worth it.
I'm now thinking of wet sanding the TB / 400 just to polish is this a good idea?
Thanks
Thanks
