Underdrive Pulley? which one?
Old 10-26-2004, 11:31 PM
02WS6Bird's Avatar
Default Underdrive Pulley? which one?
well...im looking at 2 and only 2...SLP or ASP...which one has better quality fabrication and build...they both claim 10 rwhp...and such...they do the same...its just how htey look....and function...
will these fit the 455 stroker i have planned in the future or will they needabe replaced by a specifc pulley for it?
Old 10-27-2004, 12:54 AM
jrp
SN95 Director
jrp's Avatar
asp, crank snouts are the same regardless of stroke
Old 10-27-2004, 01:03 AM
Worm's Avatar
Everyone uses the ASP, not sure why. Any SFI approved pulley should be sufficient, and the pulley will work fine with a different shortblock. Although I don't see why it would matter.
Old 10-27-2004, 01:21 AM
35th SS's Avatar
asp here on both cars.no problem taking out and putting it back in.
Old 10-27-2004, 01:32 AM
2MuchRiceMakesMeSick's Avatar
I have ASP, no problems here.
Old 10-27-2004, 04:11 AM
LS1LT1's Avatar
Go with the ASP.
Old 10-27-2004, 10:57 AM
Retired Street Racer
Matt D's Avatar
asp
Old 10-27-2004, 03:01 PM
02WS6Bird's Avatar
SLP's looks like it holds the belt in a bit of a slot...check it out guys?...is that actaully any good?...or it really wont serve any purpose what-so-ever?
thanks all...Keep me posted...and keep 'em (opinions) comin
Adam
Old 10-28-2004, 10:33 PM
02WS6Bird's Avatar
http://www.slponline.com/view_produc...1&BIG=100221-1
then theres this
http://www.ls1speed.com/catalogimage...S1_pullies.gif
the SLP looks more effective to me....and it looks like it has more improved design
however it says throwing belt is common but since i dont kno about pullies i woudlnt kno if thats true
is the SLP design actually a really good one....any1 kno Pros/Cons?
Old 10-28-2004, 10:42 PM
Lesrace82's Avatar
With these being elastomer dampers. Is there any harm putting them on aftermarket rotating assemblies? Wouldnt a fluid type damper be better for different harmonics? Maybe im looking at it wrong, but wouldnt there be different harmonics from a stock rotating assembly to a forged set up?
Old 10-29-2004, 12:04 AM
ls1fbod's Avatar
For SLP u'll be payin for the name....go with asp
Old 10-29-2004, 05:19 AM
PREDATOR-Z's Avatar
Pulley is not for power or looks, its main purpose (often overlooked) is to absorb bad harmonics, so MARCH will take my vote (fluid dampner).
Old 10-29-2004, 06:29 AM
02WS6Bird's Avatar
any1 TTT?
Old 10-29-2004, 05:21 PM
LS1LT1's Avatar
Lightbulb
Well for looks no, but most people (with an already smooth running motor that is) DO in fact put a n underdrive pulley on to go quicker/faster, no?
Old 10-29-2004, 05:25 PM
Yeah, thats why I got it. It might take .1 .2 tenths off. It will also smooth out the harmonics as well.
Old 10-29-2004, 05:30 PM
P Mack's Avatar
I ordered the march pulley. A fluid damper for less than the ASP pulley, can't beat that (sdpc had them on sale). I don't know if i'd say it's not for looks, the stock pulley looks so crappy. If nothing else, i think it's easier to use the a harmonic balancer puller than a 3 arm puller, so that's a plus. Hey Ali G, why'd you take your mod list down?
Old 10-29-2004, 07:26 PM
02WS6Bird's Avatar
is there tuning needed after the install of either pulley?...or no
doesn't seem like it but thats what i said about LT's lol
Old 10-29-2004, 07:40 PM
Fast Eddie's 02 T/A vert.'s Avatar
I have the ASP pulley, I've never had a problem with belts coming off or anything like that. I took a tenth off my 1/8 mi. time.
Old 10-30-2004, 01:08 AM
LS1LT1's Avatar
Lightbulb
No, no tuning required but if I were going to be getting tuned soon anyway I would be sure to put it on before just in case.
Old 10-30-2004, 01:20 AM
PREDATOR-Z's Avatar
What I meant was that we sould base our pulley choice on:
1- Harmonic absorbtion (the most important function) remember KR problems with ASP old design???
2- power
3- looks
4-weight (negligent as it is centrifugal weight)
