O2 sensor Problems need help!!!!!!!!!
I have a problem, i put Jet-hot long tube headers on my car about 6months ago. Now i am having problems with my O2 sensors, they keep malfunctioning on me. When i took them out they were really black. I also put a air/fuel gauge in my car, and the gauge is going crazy. When i am either at idle or just cruzin the gauge goes from 2 light in rich to the last light in the lean. Can anyone please help me, These O2 Sensors are very expensive!!!!!!!!!!!!!!!!!
1 Post
Um.. are you gauging your O2s being bad on the movement of your A/F guage... The A/F is supposed to move back and forth like that.
If your O2s were taking a dump, your car would be running like ***? Is this the case?
Let us know some of the symptoms.. The O2s are going to be black because they're in the path of the exhaust exiting the car. Nothing but carbon build up..
The symptoms that i have are that sometimes, after i let my car sit for awhile (it doesn't happen everytime) The car won't start. It starts but it won't idle and i have to turn it off and just turn the key on and sit there for awhile. Then it starts up fine. Then there is the thing of the O2 sensors going out.
I have been getting codes (SES Light) on my passenger side o2 lately as well. Im going to replace my o2s with the corvette rear (after cat) sensors, which are rumored to have a higher wattage heater for more accurate readings in the cooler exhaust further down the header.
-T
-T
1 Post
-T
-T
Do you have headers? Maybe you have a fried wire due to header heat. I did.
I wrapped the lower portion of my headers to the collectors with wet header wrap, clamped the tape, and then let it dry. I did this to keep the collectors and 02s toasty.
Have not had a code since.
