carb on a ls1/ls6
Old 11-22-2004, 12:11 PM
stangeater01's Avatar
Default carb on a ls1/ls6
has anyone ever done this or know about this? I was looking in jegs and there is a kit to put a 4 bar. carb on the ls1/ls6 what would be the benfits of this?? would you gain more hp then you would with the fuel injection and the intake manifold?? and help would be appreciated
Thanks
Old 11-22-2004, 04:12 PM
z98
z98's Avatar
Yeah, you'd make more power from the intake, not really the carb. A big single plane is better for top end HP.
I wouldn't mind a big single plane intake with an 1100 CFM TB on top.
Old 11-22-2004, 04:19 PM
technical's Avatar
Retro-fits, hybrids, street rods, etc. are typical applications for the carb setup.
Old 11-22-2004, 04:37 PM
ddelallata's Avatar
I think I read somewhere that with the Edelbrock manifold and carburetor only 1 hp was gained.
Old 11-22-2004, 09:31 PM
thanks for the help so i guess it is not the best way to go.
Old 11-23-2004, 02:40 PM
z98
z98's Avatar
Why do you say that?
The cost? The hassle?
Old 11-23-2004, 08:24 PM
i guess the cost and the hassle b/c you can buy the 90mm fast intake and 90mm tb and gain just as much hp and its a direct bolt on no wires to deal with + you will probably need a bigger hood. think about it the intake with the carb sitting on it then a air filter much taller than the regular intakes
