3" TD's too much flow??
My search didnt get the results I was looking for, so I was wondering if 3" td's would kill my tq and power down low while its still just a bolt-on car? I was planning on getting this setup when I did H/C (way later), but my friend wants to trade his 3" td's for my 3"QTP ory, so I figured I need to get it while its free!! A few people said the car would run like a dog on the street if I didnt at least have a cam. My friend has the TR230 so theres no comparison. Just wanted to get your thoughts/experience on this. thanks!!
!LS1 11 Second Club
[QUOTE=BLASTER]
Or if you're stock height.
I also let go of my 3" TD's for a QTP Y-pipe. Gee wonder why?
Originally Posted by Z28Venom
The only real downside to 3" true duals is the clearance. Other than that, you're good to go.[/QUOT
Only if your low.
Only if your low.
11 Second Truck Club
I have good clearance, just went over 3 speed bumps yesterday. Normal sized ones at that. I didn't scrape and haven't scraped on anything in the week I've had it installed. It tucks nicely but I do have the stock tq arm.
Only downside for me is it's freaking loud as f>@k!
!LS1 11 Second Club
Originally Posted by BLASTER
Why? clearence? You had a real nice system.
The lack of clearance was really hindering my around-town driveability- especially parking garage ramps.
Get 3", do not worry about your low end it will be fine. If you are not lowered then properly installed 3" duals will be okay. Just take it easy in a situation where it may bottom out, better safe than sorry. They sound badass too
thanks guys, i'm not lowered, nor do i plan to be, so i should be ok there. I got some HUGE speed bumps in my neighborhood and havent scraped yet. Glad to hear it wont kill my bottom end til i can afford h/c (it could be while).
I've heard of people with bolt on LT1's complaining of a little low end loss with 3" TD's over the 2.5". One of the guys, "Robbie" on camaroz28.com has 2.5" true duals with an H pipe, Hooker LT's, and CAI, and he has said he didn't really lose any low end. But a friend of his with 3" TD's on a bolt on car said that his 6th gear is kinda useless below 60mph. Robbie said his 95 T/A pulls better in 6th at lower speeds than his friends 6spd bolt on LT1, both being 3.42's.
However, I'm not sure LS1's would be affected as much with the better heads. Most cars seem to work well with the TSP system with stock motors.
Jason
Jason
That's what she said...
im getting so freaking pumped up!!
UPS needs to stop and install my LT's/duals on their truck and haul *** to my house
how much HP do you guys predict i'll gain over my stock manifolds/cats/y-pipe/clogmaster setup i have now?
btw - the headers are pacesetter coated race series and a TSP true dual setup
Originally Posted by blkZ28spt
On a 98 with LT's, 3" duals, and a lid......nothing more....through an unlocked stock converter mine made 337 rwtq peak AND 325+ rwtq from the start of the dyno run (3.4-3.6k) through 5k. Now, granted, ~3500 isn't exactly low engine speeds but it's not high and it was only 12 rwtq below my peak at that point. (peak at ~4400) Adding a converter and tire (and CAI) I pulled a couple 1.72 60's
I pick up power across the board as well. though i can tell i have alot more topend than anything else. My car pulls real hard from a roll on the highway. I pulled the **** out of an '03 Cobra last weekend from a 60 punch (3 car lengths). we also went from a stop & it was side by side till about 75-80 then i started to walk away.
for what its worth my power didnt really start to climb untill 4,400 RPM with peak HP a hair shy of 6,100 RPM
