still wont start
Old 01-12-2005, 09:35 PM
LSONE's Avatar
Unhappy still wont start
alright, i fixed the wire going to the altermator and it still wont start.
the battery is fully charged, and firmly connected with no corrosion. when i turn the key the volt meter reads ~10, in the yell0ow zone. when i try and start it it cranks over once and then makes a loud clicking noise. any ideas on the cause of this problem???
Old 01-12-2005, 09:48 PM
LSONE's Avatar
common guys, i cant be the only one this has happened too...
Old 01-12-2005, 09:55 PM
fast98's Avatar
check your starter ground and your battery cable to the starter, did u do a voltage drop of the starter positive cable? and how sure are u the battery is good, try jump starting the car or starting it with a charger on it.
Old 01-12-2005, 10:01 PM
chevymec's Avatar
Maybe the battery has lost the cranking amps. Really sounds like a weak battery if it turns over and then the starter starts clicking.
Old 01-12-2005, 10:18 PM
LSONE's Avatar
well, let me fully describe what happened.
after my cam install, everything was fine. as i drove the car, i noticed the voltage was gradually dropping, untill it got so bad that now it no longer starts, this all in about 2 days. i poked around the alternator a little and realized that the red wire comming out of the top was ripped out, so i fixed this tonight but i'm still haveing problems and it wont start.
LSONE's Avatar
oh, i have a battery charger and it reads full power, i have not tried to start the carr off of the battery charger though, should i do this?
Old 01-12-2005, 10:21 PM
chevymec's Avatar
If the charger has a Crank or start position , use it. Turn it to that and wait just a bit and then crank it. Driving around on just a battery and no alternator probably took a toll on the battery.
Old 01-12-2005, 10:23 PM
LSONE's Avatar
alright, i'll see if this helps, brb...
Old 01-12-2005, 10:25 PM
chevymec's Avatar
ok, good luck
Old 01-12-2005, 10:26 PM
StyLishSS's Avatar
sounds like your alternator is dieing.. replace it for like 80 dollars. i before had same problem
Old 01-12-2005, 10:29 PM
LSONE's Avatar
alright, when i take the battery fully out and hook it up to the chargers, it says its fully charged, but when i put in in the car and attach the chargers, it says its empty
Old 01-12-2005, 10:36 PM
chevymec's Avatar
Sounds like you need to have the battery checked but you will probably gettin a new one.
Old 01-12-2005, 10:38 PM
LSONE's Avatar
glad i have a warrenty on this thing... thanks for your help, i'll post what ends up happening when i'm done
Old 01-12-2005, 10:40 PM
chevymec's Avatar
Sounds good!!
Old 01-12-2005, 11:19 PM
14u2nv's Avatar
Just replace the battery with an Interstate if available. If you race a lot you might want to consider an Optima! I would yank the alternator and have it checked while swapping the battery. If your T/A still has the OEM battery...definetly replace it.
Old 01-12-2005, 11:44 PM
LSONE's Avatar
well, the problem ended up being this.
when i put the battery screws into my battery and attached the charger it said it was charged for some reason, and it wasnt. so i took the rubber covers off the top and charged it that way, now everything is fine. thanks for the help!
Old 01-12-2005, 11:53 PM
BLASTER's Avatar
Sounds like the battery. Did you try jumping it? or you can start off of the charger if you have "crank" capability?
Same happend with my truck and jumped it from the TA. Battery still read around 10V but did not enough current (amps) to fire up. Soon as I fired it up the voltage jumped up to ~13 so I knew it was definately not the alternator. Made sure battery was getting charged from the alternator when it was running and did some tests to make sure. Battery would only hold a starting power for ~2-4hrs before getting very weak again. I think I stretched it out to 12 hrs but had to hold the crank and believe it or not, pump the gas to get it to turn over. Replaced with a Optima Rad Top and problem solved.
Maybe this was your scenario......started up and ran off battery since your alternator was disconnected/faulty connection, resulting in you draining all potential starting power from your battery. Maybe a good charge is all you need. Just jump it, make sure the alternator is charging, ride around for awhile. If it is dead again, go and replace.
Old 01-13-2005, 12:00 AM
LSONE's Avatar
how can i tell if my alternator is chargine for sure?
Old 01-13-2005, 12:10 AM
BLASTER's Avatar
Voltmeter. Voltage should read between 11-12 when the car is off (battery voltage) and should jump to 13-14 when you start it and it is running (alternator output). You can measure at the battery posts or at the cigarette lighter. I have a conveniant digital one (from Jegs) for the cigarette lighter just for convenience so I don't have to bumble around with my meter.
Old 01-13-2005, 12:11 AM
LSONE's Avatar
sounds good, i'll check it out tomarrow!
