Header Install Help???
Hello,
I just got my QTP headers and the passanger side went it quite easy, but I am having trouble getting the drivers side in. I have taken off the steering linkage and valvecover and still dont have the room to slide it down. I can only get the car up off the ground about 13". Does anyone have any ideas of how I can get the header to go in???
Thanks
Thanks
I think the car height might be your problem, but for me I had to get the passenger side up higher to get my headers in. You might also want to try grinding or cutting off the block tab. Here are the instructions I used. You also should look at JRP's bolt-on FAQs, I think he has an install guide too.
Kevin
Kevin
Originally Posted by 2002RamAir
Hello,
Thanks
Thanks
While I don't have qtps, (i have jet-hots) after getting my car 19in off the ground it made things easy. I think that is your main problem.
Or you could just drop the motor
How about would I go getting the car that high off the ground?? Is it safe to just jack up the one side 19 or so inches??? If not would it be okay to say jack up the passanger side say 13 or so inches and then jack up the other drivers side to the 19??? I am just afraid of breaking or twisting something I shouldnt.....
I have my car up 22' and they slid right in. I did not have to remove anything else, not even the plugs or oil filter. It fits in forward of the K-member support, not back by the oil filter. You need the car higher. You must be carefull!!!
Buy or borrow some very large jack stands. I would NOT jack up half of the car much higher than the other side or front to rear. You do not want it coming down on you, Not worth it!!
Jack it up in increments and take your time.
Good luck and be SAFE!!
Why exactally would you have to jack up the back along with the front???
Originally Posted by fasteddyss
I don't know about you but I would not get under a car that was jacked up 19" only on one end. Maybe just paranoid?? That just seems to unstable. Better safe than sorry.
Originally Posted by Quick Time
Pull the oil plug and the oil filter and get the car as high as you can. Call us if you need more assistance. We just did an install for GMHTP mag and the took 30 secs to put the driver side in.
