Pacesetters New Fitment?
Old 02-14-2005, 11:27 AM
VoodooWS6's Avatar
Default Pacesetters New Fitment?
Has anyone installed these latley? Do you still have to notch the K-member? I am not feeling good about opening the car up to rust issues later down the road by banging or cutting into metal on the car. Any suggestions?
Old 02-14-2005, 11:34 AM
Flaminchiten67's Avatar
Do a search this topic has been covered many times in the past couple weeks
Old 02-14-2005, 12:04 PM
jrp
SN95 Director
jrp's Avatar
there havent been any major problems since the redesign that was done over a year ago.
Old 02-14-2005, 12:21 PM
Crazy Man's Avatar
Mine went in fairly easy.
Old 02-14-2005, 12:29 PM
Moderator
JayplaySS's Avatar
Default Just Put Them In!!
Just got a set 2 months ago, no problems at all! They slid right in, in fact, when i slid em in and let it sit, they wanted to fall right out from the engine bay onto the floor! Easy install! Reuse your header gaskets though. Go to NAPA and get 3 inch muffler band clamps!! Takes care of the leaks! Loose the cats too.
Old 02-14-2005, 12:33 PM
FineWine's Avatar
I just ordered a set after doing some research. It seems the redesign has helped a lot
Old 02-14-2005, 02:44 PM
GT Griller's Avatar
I put mine im last week and no need for adjustment. No nothching anything.
Old 02-14-2005, 02:53 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Just put mine in a couple days ago, the drivers side barley fit - had to give it a few good hits untill it went into place. Passengers side slid right in no problem. I was actually really impressed with how well they went in, I thought for sure that I would have to do some notching etc.. Very good product for the price, welds were nice as well.
Old 02-14-2005, 05:14 PM
Full-Force's Avatar
It seems odd that you had to hit them at all. Different people will put them in different as far as what angle you install them from. Honestly, these headers could not have went in any easier. It was as simple as getting under the car and just lifting them into place. There is no way that a more eexpensive header would fit any better, no way. There comes a point where it can only fit so good and these are at that point. The best 375 bucks I have spent.
Old 02-14-2005, 05:55 PM
Ferocity02's Avatar
Mine went in really easy. The passenger side took some work just to get it twisted right so it would go up in place. Once it was in place though, it kept trying to fall out from under the car. The new Pacesetters are really nice pieces.
Old 02-14-2005, 07:10 PM
CHIWS6's Avatar
the only problem i had was on the drivers side, i had to loosen the engine mount and lift up but no big deal. other than that it was easy. but u have to have a lot of patience!!!
Old 02-14-2005, 07:19 PM
Bad Seller Warning!
SoSlow's Avatar
Mine went in easy all I had to do was disconnect the steering shaft,the ORY was also an easy install.
Old 02-14-2005, 09:14 PM
Full-Force's Avatar
oh yes, almost forgot ... i did take the steering shaft loose and swing it out of the way
that costed me an extra 5 minutes tops
Old 02-14-2005, 09:17 PM
Ferocity02's Avatar
Only thing I had to remove was the starter motor. I didn't have to disconnect the steering shaft or lift the motor. I guess all cars are a little different.
Old 02-15-2005, 08:30 AM
LS1TECH Sponsor
Steve Burger's Avatar
We had to disconnect the steering shaft on the set we just did. Other than that it was easy. Disconnecting the steering shaft is a lot easier than messing with the engine mount and provides the same if not more room.
Old 02-15-2005, 09:26 AM
Raise's Avatar
even if u must knotch the k member, just sand down the little edge u knotched, then primer and paint over it. that should protect it well enough. then maybe slide a piece of rubber hose in between so as to not scrape the paint off if the header should want to hit it.
Old 02-15-2005, 02:26 PM
ninobrn99's Avatar
my install went very smoothly. great clearance and everything. not a bad header at all!
Old 02-15-2005, 05:42 PM
NY01ws6's Avatar
I just bought a set of pacesetter headers. I had a problem with them they had some high spots on the flange so I had to call them direct, there customer service sucks but they sent me a new one anyway. The headers were decent i've installed other headers on other cars so i have a good idear whats out there and i agree they are a good quality, but if you have a problem dont count on them to help you out
Old 02-20-2005, 09:42 PM
wymanh's Avatar
Question Major Help!!!
Where in the hell did you buy your Pacesetters LT headers from? I have been looking everywhere.
Old 02-20-2005, 09:43 PM
FineWine's Avatar
eBay, Texas Speed and Performance just to name the two on top of my head. I haven't had a probelm finding them ::shrug::
