ASP UD Pulley Question
I want to buy and ASP Underdrive Pulley for my 2001 SS Camaro, but it is an automatic and i need to know if im gonna have to get the alt. overdrive pulley to keep it charging right. And if i do get the Alt. overdrive pulley will it cause me to get any less power out of the underdrive pulley? Also, what kind of gains will i see with the pulley/pullies???
Thanks.
Thanks.
I was fine with the crank pulley only. You need a new bolt, two new (different size) belts, and the UD pulley itself. I just sold mind. You might check the FS section.
Thanks for the info. I've got 410 hp and run high 12's in the 1/4 - so if i get the UD pulley will I be able to feel any difference at all, and about how much time will it knock off my 1/4 mile?
Originally Posted by 1badV6
You'll be fine with just the crank pulley. You should torque it to specs 150FT lbs of TQ!
or more!!....and use antiseize, you dont want that sucker comin off!!
