cut out = SES
Old 04-28-2005, 06:11 PM
jorgez28's Avatar
Default cut out = SES
after running with it uncapped did you guys get an SES light
Old 04-28-2005, 06:17 PM
Jeffs99SS's Avatar
Nope. Drove around with it open for months at a time (until I went to LTs and ORY). If it's throwing a code you've got something else going on. BTW, this is with the cut out installed in the I-pipe under the rear seat pan.
Old 04-28-2005, 07:38 PM
BrandonDrecksage's Avatar
do you have it installed before cats? if so...you'll probably get acode for the cat below efficiantcy(sp) but if its after the cats..diff problem...got get you car scanned..autozone does it for free
Old 04-28-2005, 07:39 PM
SupahRich's Avatar
I never had a problem with the SES light and cutout... not until I took the cats and manifolds off
Old 04-28-2005, 07:44 PM
Redneck Z's Avatar
I don't think the ses light could be related, unless your cutout is before the cats. Also, autozone will not scan your car in california. What a wonderful state.
Old 04-28-2005, 09:10 PM
Uno99's Avatar
Never had problems with mine throwing code. Maybe if the cut-out is place to close to the O2 sensor. Were is it welded in?
Old 04-28-2005, 09:14 PM
8-Pack's Avatar
I have used the scanner from them a couple of times. But this state still sucks.
Old 04-29-2005, 02:02 PM
jorgez28's Avatar
I got it scanned and is was the efficiency code so I capped it cleared the code and it hasn't gone off since. btw the cut out is right before the int pipe goes over the axle
Old 04-29-2005, 03:14 PM
SSBRONCS's Avatar
i HAVE LEFT MY CUT OUT OPEN FOR ABOUT A MONTH WITH NO ISSUES
Old 04-29-2005, 03:15 PM
if the cutout is after the cats..it won't affect them...how many miles are on your cats? one of mine crapped out at 50k and the other at 56k
Old 04-29-2005, 04:25 PM
2001NBMZ28's Avatar
P0420 or P0430? Sounds like one of the cats are on the way out.
Old 04-29-2005, 07:31 PM
02 Camaro SS's Avatar
if it's right before the axle how does it effect any sensor readings?
Old 04-29-2005, 09:01 PM
SupahRich's Avatar
It shouldn't set off a code if it's in the I-pipe in the passenger rear seat area... there are no sensors past the 2 rear O2 sensors behind the cats I have my cutout uncapped for several months before I installed the headers and never saw a code with it.
Old 04-30-2005, 07:38 PM
that's what i figured. he said the code hasn't gone off since he recapped it. that doesn't make any sense
