Awesome! Blew a hole in my FLP header - WTF!?!
Old 04-30-2005, 06:47 PM
Obliviously Obvious's Avatar
Default Awesome! Blew a hole in my FLP header - WTF!?!
I'm at a loss for words...
Drove to and from the store and on the way back, the car sounded funny...
Popped the hood, and:
http://www.debowfamily.net/img_0039.jpg
WTF would cause that?!?!
Any fix? Like, patch weld it or something?
Old 04-30-2005, 06:50 PM
blkZ28spt's Avatar
WTF?!?!
Old 04-30-2005, 07:07 PM
camdavgar's Avatar
It was where the air tube use to go. I have heard of a few people that had that happen with different brands of headers. I guess it's a weak spot in some. I don't knwo what you can do to fix it. I would guess just weld a piece over the hole.
Old 04-30-2005, 07:09 PM
Ya know what, your sure the hell right. AIR tube is gone!
Old 04-30-2005, 07:14 PM
felton316's Avatar
Must have been a bad weld.
Interesting thing about that.. I've *NEVER* had the AIR system hooked up to it.. not like it was under ANY stress what so ever..
Good to know my $1200 was well invested in a quality product.
Old 04-30-2005, 07:42 PM
ddelallata's Avatar
I've seen that happen before too....with other brands, but never with stainles steel.
Old 04-30-2005, 07:47 PM
cyphur's Avatar
x2. only really seen it w/jet hot and hooker lt's.
are FLP headers stainless? thought they were coated. if SS, i wouldn't think they used the same high quality 304? that kooks and QTP uses.
Old 04-30-2005, 07:50 PM
Do any of you have an opinion as to if I can 'patch weld' this thing? Or am I shopping for another set if headers?
Old 04-30-2005, 08:13 PM
setxws6's Avatar
That happened to a buddy of my a couple years back on his LT1 shorty headers. But, his hole wasn't THAT BIG! He had it spot weld I believe and it's been fine since.
Old 04-30-2005, 08:18 PM
calongo_SS's Avatar
You shouldn't need new headers, that can be fixed.
Old 04-30-2005, 09:04 PM
Another_User's Avatar
"car sounded funny"....I bet it did! That sucks.
Old 04-30-2005, 09:06 PM
CRASH 02's Avatar
You should be able to patch that. And no FLP's aren't SS. Here a pic of what my old FLP's looked like when they were less than a year old. I had to send them back at my expense to have them re-coated.
Old 04-30-2005, 09:21 PM
tim99ws6's Avatar
It's happened to the $$$$$ LG corvette stainless steel headers. It's a weak spot that over time from the change in temperatures i assume flex that small bead-weld, and make it pop off. It's happened to mine also(hooker LT's), and i just welded it shut, and moved on.
Old 04-30-2005, 09:26 PM
mr2guru's Avatar
Weld it....a shop could probably weld a patch while on the car
Old 04-30-2005, 09:30 PM
Blacker's Avatar
I had that happen to my Hooker LT's. In order to repair it, the header had to be removed. It is a tight space and the AIR Tube is not easy to weld around unless the header is removed. After that happened, I bought race headers and don't have to worry about that weld.
Old 04-30-2005, 09:37 PM
I've never had AIR on my in years.. I'll just seal it shut if they can do it on the car. What a PITA if I have to take it off.
Old 04-30-2005, 11:17 PM
nick3205's Avatar
I had never heard of that happening. Guess you learn something knew every day.
Old 05-01-2005, 01:00 AM
Dragula's Avatar
That's doesn't look like a bad weld. If it was you would see weld still there.
Old 05-01-2005, 01:28 AM
felton316's Avatar
If its like the others that have blown off their AIR tubes, what the problem was, that they were welding dissimiliar metals and did not get the penetration into the primary tube. If he can find the AIR tube, it probably still has a 'nice looking' bead around it base. Good looking welds are not always good welds.
Quick Reply: Awesome! Blew a hole in my FLP header - WTF!?!
