quick question. where is the low side a/c port for recharging a/c?
I need to recharge mine and I am not sure where this low side a/c port is. Instruction said to use that port when recharging the a/c. Thanks!!!
Originally Posted by WhiteRhino
Its the port closest to the firewall.The fitting will only fit on 1 port.They're 2 different sizes.The 1 at the condenser is the high side.
click for the picture
Moderator
Best is to go by low side pressure when you are
running the A/C full blast. Get a fill kit with the
gauge (if you don't want to go whole hog and
get a manifold gauge set). Add juice until you
get close to the top of the indicated low side
pressure "good zone". Blow the rest of the
can off to help clean out the ozone layer, or
just use the whole can and see if you go over.
Not a big deal, excess low side pressure, as
long as you don't start slugging liquid into the
compressor.
compressor.
Originally Posted by iwantLS1
i think the system needs about 1.5lbs of refrigerant. about 3 16oz. can should do it.
I'd do what jimmyblue suggest unless you have gauges.If you're unsure you should take it to a shop.Its a real exspensive mistake if you mess something up. ie;compressor damage!
