1 cut-out or 2
1 cut-out or 2
I'm finally getting my exhaust and I wanted to add a cut-out with it .My question is, if I get 2 instead of one,will it be louder and give me more hp.
The exaust i chose to get was the slp LM.Thanks for the help.
Originally Posted by CamaroRumble
I would use two cutouts because if you only used one your backpressure will be differnt and will cause problems
If you put a single cutout in the i-pipe, there's no problems. That's what most people including myself have done. There's a spot right under the rear seat that's perfect for a cutout. Don't worry, it's plenty loud!
Just wondering what the big difference would be between one cut-out on the front of the y-pipe and two cut-outs after the pipe y's out? Both are right after your headers or manifolds.
