Ahhhh!!!! What did I do!! TB Help!
Alright so I bought a shaner s3 for my car. It does have a larger hole drilled for idle, and I read that would make it idle 3-4 hundred rpm's higher. So I go to test drive it and with the clutch in the car is still at 21 hundred rpm's or so, not good! It won't go back down to a managable range until the car it completely stopped. It will go down to 11 hundred if I shift into say 5th. SO WHAT DID I DO??? THIS ISNY NORMAL IS IT?? I NEED SOME HELP!! Thanks everyone.
Ok so search decided to work and I read a couple threads that were saying this may have to do with the brake booster or possibly the AIR system??? I dont know guys I am lost but this is my only car so I need to get it fixed.....I really shouldn't work on my own car
LS1Tech Administrator
Received 1,492 Likes
If the hole in the TB blade is enlarged, it will cause all the things you described. You need to either fill the hole (JB weld, etc.) and drill a new one to stock size (almost positive 5/32" is the stock hole size) or get another TB blade. You can't get a new TB blade from GM without buying a whole new TB, but I've read in the past that one of the sponsers has extra TB blades in stock for the factory TB. I beleive it was TPiS, maybe try contacting them.....
Originally Posted by JakeY2KZ
Do an idle relearn on the car first and see if that corrects it.
I bought it from a guy who had them do it. I expected the 11 hundred idle, but not the 22 hundred riding rpm.....will driving help, or should I get off my *** and go change the blade?
Agreed don't drill anything on a stock TB. Get another stock one if you can and try that first. Use the idle screw for tuning with proper computer turning to build upon it. If you can't do it just have it professionally done. No use messing with it if you don't know what to do.
Put the stock TB blade back in. Drive it for a little while like that, and after some miles and a few restarts all should be back to normal.
My stop screw was in upside down, got that fixed, got it hooked up to the tech 2 at the dealership, now its all good. Idle is like 3 hundred rpms higher. We'll see if it stays fixed. Thanks guys
PS. If the idle is still 300rpm higher than the desired idle speed programmed into the PCM, then you will eventually get an SES light for a high idle code. Mine would throw that code once the idle was about 200rpm higher than what the PCM was set for.
"idle relearn"....just like driving around and hoping that fixes it, right?? I can do that. If that doesnt work I still have my stock TB and I will take the blade off of there.
A buddy of mine had the same thing happened to him when he put his S2 on his car. I told him to do the idle relearn process and the high idle went away. He didn't even have to mess with the stop screw.
Automatic Transmission:
1 Turn off the ignition
2 Restore the PCM battery feed
3 Turn Off the AC controls
4 Set the parking brake and block the drive wheels
5 Start the engine
6 Allow the engine coolant temperature to reach 176 degrees F
7 Shift the transmission selector into the drive range
8 Allow the engine to idle for 5 minutes
9 Turn on the AC controls (Omit for 2000-02 model)
10 Allow the engine to idle for 5 minutes (Omit for 2000-02 model)
11 Shift the transmission selector into Park
12 Allow the engine to idle for 5 minutes (Omit for 2000-02 model)
13 Turn off the AC controls (Omit for 2000-02 model)
14 Allow the engine to idle for 5 minutes
15 Turn off the engine for 15 seconds
Manual Transmission:
1 Turn Off the ignition
5 Transmission in neutral
6 Start the engine
7 Allow the engine coolant temperature to reach 176 degrees F
8 Turn on the AC controls (Omit for 2000-02 model)
9 Allow the engine to idle for 5 minutes (Omit for 2000-02 model)
10 Turn off the AC controls (Omit for 2000-02 model)
11 Allow the engine to idle for 5 minutes
12 Turn off the engine for 15 seconds
Idle relearn will not fix it completely if the hole is too big. Period. I've been through this.
