Which is THE BEST cat on the market
Old 02-10-2006, 11:20 AM
FSUNole17's Avatar
Default Which is THE BEST cat on the market
I am looking for a cat to put in a ypipe that will last, flow good good numbers, and give decent ground clearance. ive heard random techs flow the best, but do they hold up and last a while and give good ground clearance?
Old 02-10-2006, 11:46 AM
300bhp/ton's Avatar
STOP!!!
Sadly there's no cat good enough to handle the flow from all 8 cylinders. You HAVE to run two cats, one after each header. This way they only have to handle the flow rate of 4 cylinders.
According to David Vizard, we require 2.2cfm per 1hp to not affect exhaust flow, and thusly bhp output.
So on a stock Fbody with ~345bhp thats (345 x 2.2) 759cfm for all 8 eight cylinders.
Which is well beyond any cat. Evidently running two cats means they only half to deal with (759 / 2) 380cfm which is much more managable.
Random Technology's 7000 Series Metal Matrix cats are very good (I think LG Racing uses them in their Corvette systems). The 3" variants can flow 598cfm, so well in excess of a stock Fbody, but not good enough to run in the I pipe. These are best cats I know of.
598cfm is good for ((598 / 2.2) x 2) about 545bhp at the engine without any restriction, if you run two of them. But they are pricey.
Random Technology also offer their 9000 Series cats, these in 3" inlet/outlet for flow 502cfm so pretty darn good, but they are physically a lot bigger than the 7000 Series ones.
I think but I'm not sure, the Magnaflow Carsounds cats flow somewhere in the mid 400cfm range, so pretty good and a lot cheaper also. A slight restriction won't be much of a problem unless you are running boost and high bhp levels.
But don't run a single cat in the I pipe.
EDIT: I see from your sig you have the TSP catted Y pipe, I believe they use the above mentioned Carsound cats. They are not posing an issue with your current mod status, even if you add a cam I doubt the cats would be sucking up any more than 10rwhp, if that. And if you are having ground clearance issues, then adjust your Y pipe. If that doesn't work you have quite simply slammed your car too much. In stock trim they already have quite low ground clearance and shouldn't really need lower much if at all.
Old 02-10-2006, 01:31 PM
weestro's Avatar
Yep, RT 7000 metal matrix is the best and doesn't need AIR like the ceramic cats. They're $$$ but the quality is extremely high and at 4" round they tuck well.
Old 02-10-2006, 01:59 PM
FSUNole17's Avatar
Originally Posted by 300bhp/ton
STOP!!!
THANK YOU!! for a very in depth analysis of this, it brings to light basically all the answers to the questions i had...... i think you misread my post, i never intended to run just one cat, i knew iw ould have to run 2 anyways, do any of the vendors on this site sell the 7000 series cat? and i saw where u said it is 4", if i have a 3" Y pipe, do they also make them in 3" or would it be impossible to get them onto the 3" pipe, thanks!!!
Old 02-10-2006, 02:04 PM
weestro's Avatar
4" round at the largest point of the body. They come with in/oulets of 2.5 and 3". It'll work fine in your 3" pipe.
Old 02-11-2006, 05:29 AM
300bhp/ton's Avatar
yep 4" is the body diameter, but you'll want the 3" inlet/outlet ones. Random Tech sells direct if you go to their website plus they have a list of dealers on there also.
Old 02-11-2006, 08:23 AM
BrandonDrecksage's Avatar
best cat is a hallowed out cat
Old 02-11-2006, 03:14 PM
oxidizr's Avatar
Car Sound / MagnaFlow has a new offering and market price will be much more reasonable. Check out this thread:
https://ls1tech.com/forums/generation-iii-external-engine/448747-high-flow-cats-ones.html
We have some prototypes for all out race classes requiring cats with 200 cell density metallics to support 640+ CFM / 4" substrate and another completely unique design part which will flow a tad bit more specifically designed to last high boost without the subtrate style core... stay tuned.
Old 02-11-2006, 06:34 PM
300bhp/ton's Avatar
Cheers for the info, sounds pretty darn good to me And all the better for those like me who HAVE to run cats.
Old 02-11-2006, 09:19 PM
Louie83's Avatar
Agree. It's also good for those like me who WANT to run cats.
Old 02-11-2006, 10:29 PM
Blk02Ls1A4's Avatar
Hmmm, very nice. I will be in hte market for a set soon when I start collecting parts for duals. Any eta on their availability or cost?
Old 02-12-2006, 12:09 PM
z-ya's Avatar
Dynomax powercats are metalic and compact and 1/2 the price of randoms.
Old 02-12-2006, 12:12 PM
300bhp/ton's Avatar
any idea what they flow like. Many so called "hi-flow" cats do not actualy flow high.
Marketing can be confusing. If they flow good then thats a good money for what they are.
Old 02-12-2006, 01:19 PM
PewterNHRA2001's Avatar
what about the direct fit cats that summit sells? also does anyone have a link to them, tried searching for them but no cats come up for 2001 firebirds :weird:
