need maf that will handle 750hp
Old 03-31-2006, 12:32 AM
Bad Trader Investigation in progress
98redtransam's Avatar
Default need maf that will handle 750hp
i am doing some serious work and will be pushing around 750 with 100 shot. what maf and tb do i need. heard stock only handles 500 hp. ???????
Old 03-31-2006, 08:24 AM
badaSS98's Avatar
Well,, if you have a good tuner around, you could do speed density and get rid of the MAF all together.. That's a better way to run anyway when doing power add on's because you can "fine tune" your bottom end so you don't have to run rich down low to stay good on the top end. JMO
Jay
Old 03-31-2006, 08:28 AM
mvonada's Avatar
Jay
Best way to go, **** can it.
Old 03-31-2006, 08:31 AM
ls1mongrel's Avatar
Dump the MAF and get a 90/90 setup and you should be good to go !
Old 03-31-2006, 09:11 AM
That's what she said...
TheBlurLS1's Avatar
How do you plan on making all this power?
Old 03-31-2006, 09:59 AM
300bhp/ton's Avatar
Jay
In theory isn't a MAF the more accurate of the two methods as it's constantly measuring air flow.
Originally Posted by David Vizard
Unlike an LS6, which has a mass air system that allows the computer to adjust the fuel flow for any given airflow so that the mixture is always right (theoretically at least), the Hemi has a speed density system. This means that any increase in airflow into the engine goes unseen by the rest of the system. If a modification is done that increases mass airflow, such as a cold-air package, the computer has to be reprogrammed accordingly.
Old 03-31-2006, 11:38 AM
im adding headers, true duels, 100 shot, 3200 stall, .625/.625 lift cam, ported heads, slp lid, full msd set up, shift kit, tuned, chip, ls6 ported oil pump, possibly strocked.
Old 03-31-2006, 12:31 PM
VORTECFCAR's Avatar
Your stock maf will be fine for that.
might I suggest further reading...?
Old 03-31-2006, 02:45 PM
magius231's Avatar
good luck making 750hp with that
Most people making anywhere near that power level have either a power adder or 402+CI engine with $$$$ heads.
a 3200 stall is NOT going to like a cam that has .625 lift, you may really want to reconsider your combo.
Old 03-31-2006, 02:55 PM
X-JeSSter's Avatar
An LS1...Tuned AND chipped?
Old 03-31-2006, 04:03 PM
TAQuickness's Avatar
you can try a gm 85mm maf.
In regards to some of the above statements, the maf has a higher resolution, so fine tuning can be done. However, MAF's do not like the turbulant airflow induced by high overlap cams, hence the popularity of SD.
Personally, I would !maf. one less varialbe to deal with during tuning.
Old 03-31-2006, 09:16 PM
Bad30th's Avatar
He musta been readin' Meent's sig.
You will need some kinda FI or a bigger nitrous shot or more cubes to reach into the 700 range.
Oh, and I'd skip the MSD stuff and spend the money elsewhere - there are 1000+ hp cars with the stock LS1/LS6 coils, stockers are fine.
Good luck !
Rob (Bad30th)
Old 03-31-2006, 09:21 PM
JustAnIlluzion's Avatar
750? yea right
more like 900hp to the wheels buddy, better get a 10 bolt rearend to handle all that power.
Old 03-31-2006, 10:01 PM
X-JeSSter's Avatar
Originally Posted by JustAnIlluzion
750? yea right
definitely gonna wanna use the new Q pipes for those true duals too
Old 04-01-2006, 12:39 AM
Rescue Ranger's Avatar
if you want serious help man, list up what you have done, and go from there. otherwise, ditching the MAF all together seems the best way to go.
Old 04-01-2006, 02:09 AM
Quickin's Avatar
I knew someone had the key to making big power all motor.
Old 04-01-2006, 07:43 AM
chill, i wasn't saying id be pushing that much power with that, my goal is to reach 750 and that is what i have so far, wanted info on maf to finish project.
Old 04-01-2006, 10:39 AM
Quickin's Avatar
Actually 750 FWHP "INCLUDING" the 100 shot is totally doable. If we're talking FWHP.
Thats just 650 FWHP on motor. Thats a cake-walk now-a-days with almost any cubes and the right set-up.
Old 04-01-2006, 12:54 PM
Ric
Ric's Avatar
Dude, I can't get ANY power to my front wheels.
Old 04-01-2006, 01:34 PM
98Blubrd's Avatar
I hope that was a joke. But it doesn't seem like it was. The FWHP he was referring to was definately not Front Wheel HP .
