01' catching a ton of oil?? how to stop it
Old 04-19-2006, 09:00 AM
rgaynor85's Avatar
Question 01' catching a ton of oil?? how to stop it
ok 1st I do not want breathers, i have thought about it but the downsides to me out weigh the good. with that said i have a catch can set up after my pcv and it catches a ton of oil. now i know with 98+ they say to vertically mount the pcv but 01-02 have a diffrent setup so how do i keep it from sucking so much up. im happy my catch can is catching it all but id like to see it catch a little less ya know
-Ryan-
Old 04-19-2006, 07:09 PM
WILWAXU's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/482130-do-i-need-pcv-valve-catch-can.html
https://ls1tech.com/forums/generation-iii-external-engine/451559-how-remove-your-pcv.html
https://ls1tech.com/forums/generation-iii-external-engine/442131-what-do-pcv-system.html
https://ls1tech.com/forums/generation-iii-external-engine/466543-oil-consumption.html
another one:
https://ls1tech.com/forums/showthread.php?t=451559
Old 04-19-2006, 09:00 PM
LS69TA's Avatar
Mine was catching alot of oil. I just switched to 5W40 Mobil 1 and it'd now drastically less. If you want a truck pcv valve, pm me. I've got one if you want to try that route. It works for some guys.
