Ud Pulley Install Helppppp!!!! Please!!!
Old 04-27-2006, 07:41 PM
erikthegoalie's Avatar
Exclamation Ud Pulley Install Helppppp!!!! Please!!!
i got my March UD pulley from Thunder Racing today, nice looking product!
Anyway
Got the old crank off with a breaker bar, and then a pulley puller...cool so far
Now the problem....i lubed up the new pulley and placed it on the crank...however, i cant get it far enough on to thread the bolt...WHAT NOW?!?!?!? How do i get it on the crank far enough to strt the bolt??
HELP!
thanks
Old 04-27-2006, 07:46 PM
Addicted's Avatar
Search the topic and you go buy a longer bolt. The old threads have length diameter and pitch. Buy the new bolt to suck it on far enough to get the stock bolt started.
Old 04-27-2006, 08:40 PM
good idea, and by the way, i did my searching ha...just sometimes it doesnt help...
thanks...any more ideas?!??!
Old 04-27-2006, 08:45 PM
daryl2cb@yahoo.com's Avatar
he is right, also I got a bolt down at the hardware store, just take you crank bolt there and get one, get a thick washer as well to get it started. once started, USE YOUR OLD CRANK BOLT TO TIGHTEN IT DOWN. then install as par howtols1.com
Old 04-27-2006, 08:58 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Be careful to not strip the threads in the crank because you will be in a world of hurt then.
I would search and you'll find people selling a hardened steel rod / bearing / nut combination that will pull the balancer on. That's the right way to do this so that you don't risk trashing the threads in your crank, if you're not sure, take the 5 minutes to search for "stripped crank threads" and see how often it happens.
Trust me, nothing is a worse feeling than tightening down a bolt and it either snaps, or gets easy and you know you just stripped out the threads.
Old 04-28-2006, 05:49 PM
Addicted's Avatar
The Install Tool that The Alchemist was talking about:
https://ls1tech.com/forums/showthrea...Pulley+Install
The size of bolt:
Make sure you get a large washer that rest on the pulley and won't bend to much.
For the Torque specs. go to www.ls1howto.com and look up a cam and valve spring install.
Old 04-28-2006, 06:00 PM
eallanboggs's Avatar
The bolt you need to buy is 120mmX16mmX2mm. Push the pulley on with this bolt until the longer bolt bottoms out. Now finish using the NEW OEM bolt you purchased. Be sure the pulley is straight and square as you start it on. If the pulley isn't moving a little bit every time you turn the longer bolt or if it gets hard to turn the bolt STOP! Once you get the longer bolt to bottom out your past the problem area.
Old 04-28-2006, 08:37 PM
DaddySS's Avatar
Pulling it on with a bolt is asking for trouble. Get a threaded rod, screw it in, and pull it on with a nut and washer with grease on the washer.
Old 04-28-2006, 09:09 PM
SSU's Drunk Typing Whore
Lithium's Avatar
I was not thinking enough and used the stock bolt to put mine on...no problems but I was kicking myself in the *** though big time.
Its always best to use a longer bolt to get the pulley started.
Old 04-28-2006, 10:31 PM
SUX2BU's Avatar
I get them most of the way with a little air hammer. then just use the stock bolt the rest of the way.
Old 04-29-2006, 01:30 AM
A long threaded rod is really the way to go as DaddySS mention, but I got the 120mm bolt for $3 and have used it with success a bunch of times. You'd be surprised how much thread purchase you get with a bolt 120mm long. With the stock bolt you get only a few threads at first, but with the longer bolt you have an additional 17mm(3/4") of thread purchase. That's enough to walk that pulley on even if it is an interference fit.
Old 04-29-2006, 12:27 PM
SUCCESS, I went out and bought a threaded rod, cut it to 7", got a nut, and two washers (hardened)...screwed the rod into the crank, placed pulley over rod, tightened nut and watched the pulley slide right on the crank..here are some pics, put belts back on and car runs fine, I need a tune however, I just installed LT's as well...so I havent noticed gains yet, hopefull with the tune itll really make the most out of my mods!!! THANKS TO ALL WHO CHIMED IN!!! A+ advice!
Here are some pics!
Old 04-29-2006, 12:48 PM
SUX2BU's Avatar
HOLY GIANT pictures batman.
Old 04-29-2006, 12:56 PM
i know jesus very sorry!
Old 04-29-2006, 02:01 PM
Lithium's Avatar
looks good! glad you got that **** figured out...its a pain in the *** huh?!
Old 04-29-2006, 02:59 PM
ohh yeah, but everyone helped it go smoother than it was going to go!!!
Old 04-29-2006, 03:23 PM
Lithium's Avatar
good to hear...breaking that bolt loose was no easy task for me. I finally got smart and used the handle from the jack to slip over the breaker bar - much easier that way.
Old 04-29-2006, 06:14 PM
One advantage to the threaded rod method is that you don't have to be so concerned about keeping the crank from turning while you're installing the pulley. I'm sure it has a tendency to rotate, but not nearly as much as when you use the long bolt method.
Old 04-29-2006, 07:16 PM
Very very true, that is a definate plus, though I did put it in 5th gear, so turning was kept to a minimal!
Thanks to everyone again...i HIGHLY recommened this process when installing an UD pulley!
Old 04-29-2006, 08:30 PM
DaddySS's Avatar
Good move and smart approach. A little extra time to get the rod, nut and washers is well worth it - glad it worked out.
