Porting Pasesetter Y
when installing my pasesetter brand Y pipe i noticed where the driver side pipe meets the passenger they seem to cut the hole pretty small.
my question is would there be a gain from going in there and removing as much material as possible?
im guessing this is why people get the texas speed pipe right?
Moderator
I had a Texas Speed Y and the merge there had a lot
of stick-in; I ported that but then found a Jet-Hot
(ditto). Just seems to be some poor fit-up in these
Y-pipes that use a "T" style merge. I guess they
prefer to err on the long side, rather than deal with
blow-through or pinholes welding up a short or zero-
overlap fit.
It may be difficult to get to; I had to use a flex-shaft
tool inside a piece of shop-vac tube to reach up in
the Jet-Hot. I think it's worth it, to remove any dog
whistle features you can.
overlap fit.
Originally Posted by Redneck Z
There was a big lip on the inside of mine that I removed. I'd say it's definately worth removing. I didn't have any trouble getting to it with my dremel tool.
what did u use on the dremel, when i got my pacesetter Y i tried cutting this overlap out and couldnt get to it enough to make a dent i had a guy at a shop cut it with a torch for me
