traction control question?
just floor it. if the pedal gives feedback then you have it. if you just spin them all day then you dont. also it should have a button above your radio next to the fog light switch that says ASR. hope that helps
That's what she said...
Also, if there is only 1 cable connected to your throttle body running to a box by the battery, you have TCS/ASR. If you have 2 cables on the throttle body, you don't have TCS/ASR.
Tech Resident
on my 2001 formula the TCS button is right in front of the shifter below the radio and heater. it really is great in the rain. i spun the 2-3 gear shift over a BRIDGE when the road was wet and i was only taking it up to ~3k. that was scary. thank God TCS kicked my foot off or it coulda been bad!
