7mm wires too small?
Moderator
Wire diameter makes zero difference. The wire itself is
a tiny part of the whole, the performance wires are
spiral wound around a fat core with fat insulation.
None of it really matters to the spark current, though
resistance in a carbon-core wire does shed some
energy. It's all hype. All that matters is a low end-end
resistance, enough inductance that you can still hear
the radio, an insulation that doesn't melt when it lies
on the header pipe for ten thousand miles, and a boot
end that doesn't pull off the wire (F you, Taylor).
seems to run even better now, so i dont care... Anyone know anything about seafoam? my buddy says it trashes your oil, but it says on the can to add it to your oil
That's what she said...
