Trans tunnel brace
Old 06-11-2006, 11:53 PM
2002ssls1's Avatar
Default Trans tunnel brace
Trans tunnel brace (the piece that runs parallel to the driveshaft) Do I need to keep this in there? What is the purpose of this thing? The reason I ask is because my TSP ory hits it sometimes, and I even had the exhaust adjusted.
Old 06-12-2006, 12:19 AM
That's what she said...
TheBlurLS1's Avatar
I haven't had one for about a year and a half. Turn it into a Christmas tree ornament.
Old 06-12-2006, 12:20 AM
2002ssls1's Avatar
What is it there for?
Old 06-12-2006, 12:22 AM
TheBlurLS1's Avatar
I've heard it called a "driveshaft saftey brace" before, which I would guess is to keep your car from pole-vaulting should the driveshaft break at the trans yoke.
Mine would have to get through the x-pipe before that happened. You can replace it with a driveshaft saftey loop of some sort. Lakewood make a very low profile one that is cheap and works great. Most tracks require you to have one anyway.
Old 06-12-2006, 12:42 AM
2002ssls1's Avatar
Thanks for the clarification, I think I will take it out to give the exhaust more room.
Old 06-12-2006, 04:30 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Doesnt it run perpendicular?
Old 06-12-2006, 07:32 AM
Rehab is for quitters...
XtinctZ28's Avatar
+1
The only thing running parallel to the driveshaft is the TORQUE ARM and I would venture to say that you need that!
Old 06-12-2006, 11:20 AM
2002ssls1's Avatar
Ok, maybe we are talking about two different things. From what you guys are saying, the piece that I am talking about it the torue arm. I think I may have described the trans tunnel brace(the piece that is connected to the left and right side of the body, underneath of the trans). I guess the exhaust is bumping up against the torque arm, how do I go about fixing this?
Old 06-12-2006, 11:42 AM
mrhzk35404's Avatar
The exhaust is on the opposite side of the driveshaft than the torque arm. Where on the torque arm is it hitting?
Old 06-12-2006, 12:21 PM
Luna's Avatar
Are you sure you know the difference between parallel and perpendicular ? I'm pretty sure you are still talking about the tunnel brace, I doubt you're exhaust is hitting the torque arm....
Old 06-12-2006, 12:53 PM
TheBlurLS1's Avatar
Best thing would be to take some pics of what's going on. I highly doubt the exhaust is hitting the TQ arm, but anything is possible.
